Have a question. I am starting to work on PRO and I do have a question. How can I change from dd to UTM in the Map tab ? The reason I am asking is because when you have the layers from dd to UTM and wanted the caption to display label in UTM. So you know the Layer can be display in UTM and they are in correct. Yes, I am aware that you have to go to the layer's properties and then on the left side on source to check for the spatial reference.
