Hi Gustavo,A quick and easy way to restrict the functionality of ArcPad is to use Applet Toolbars and then create an App Shortcut.Using your example - the only tools I would need to take into the field would be the 'Select' tool to select the features and the 'Feature Properties' tool to launch the Form for feature editing. You can create a new Applet Toolbar by putting ArcPad into Design Mode and launching the Toolbar Editor. Select 'new' from the Toolbar Group dropdown and then build your Applet Toolbar with these tools (don't forget to add the 'Exit' tool too!).Make sure that the layer you want to work with is editable and save the map. Now you can create an App Shortcut that can launch ArcPad with ONLY the Applet Toolbar tools! Select a name and icon for your shortcut on the first tab, select your Applet Toolbar in the Applet Path dropdown on the second tab and uncheck 'Load Startup Configuration and Toolbars' on the third tab (Remember - make the shortcut on the device you will be using it on as you cannot copy Windows shortcuts to Windows Mobile 😞 ) Make sure that the forms for this layer only include the fields that you want to edit and remove the geography tab (to stop users updating feature geometry) using ArcPad Studio.The easiest way to disable functionality is to remove it from the toolbars! And using an App Shortcut means field workers can launch their own custom version ArcPad using an icon to easily identify their projects! Let me know if this works for you!Hannah
