I did not assert that the combinarion was unsupported -- I started the sentence with "If".Please do not over-interpret what I write; I might be discouraged from writing at all.- V
I'm running on 32-bit RHEL 5.4 at home, and haven't had problems that couldn't beattributed to running on a six year old P4 host with only 2Gb RAM, but I'm not using 11.2.0.3. If both Oracle and Esri don't support 5.4, then that should be a source of real concern.- V
That URL always has the current information (by definition).The support for newer patches of a certified release continues to be "assumed to work,unless otherwise noted." It's unlikely that anyone at Esri will promise support for any releasewhich has not been certified (certification tests are exhaustive and exhausting; they are notdone lightly, and usually only on the reference OS available a year or more before the ArcGISrelease date).- V
ArcSDE is certified on the "supported" platforms. This means that extensive testing has been doneon that configuration, and is known to work. There's also a "not tested, but assumed to work" statuswhich usually covers most of the patches above the specified release (unless otherwise noted). It'sgenerally safe to assume that an Update 6, 7, or 8 of a supported release will work, but less safe toassume that Update 1 of the *next* release works. For the most part, Unix releases are very stable,with working backwards compatibility, but Esri only supports that which they've tested.- V
