I am trying to figure out how I can use the field calculator with python to calculate sequential letters. For example, I would like "A,B,C,D....Z, AA,AB, AC...". I did find a code that works just fine in a regular python environment but I am having a hard time incorporating it on the field calculator.
excel - How to make a continuous alphabetic list python (from a-z then from aa, ab, ac etc) - Stack Overflow
I tried using this as the code block:
from string import ascii_lowercase
import itertools
def iter_all_strings():
size = 1
while True:
for s in itertools.product(ascii_lowercase, repeat=size):
yield "".join(s)
size +=1
and "iter_all_strings()" as the expression in the field calculator but it just gives me null values.
Any help would be much appreciated, thank you.
