Hi.. I have an excel in which the values are in degree minute second format. I want to convert all this in decimal degrees by a single tool but the tool display xy data is not highlighting even i can't add a new field in the excel to calculate it again. please tell me what should i do?
I have used an equation in excel to convert DMS to DD. Since the Longitude value is from West, I have introduced the negative sign.
The cursor position of a few values were modified, to extract the correct value.
Please find attachment below.
Hi Sakshi,
Could you attach a sample excel sheet of the existing data available with you?
I suspect that your data are not in numeric format. In order for it to be converted, your degrees, minutes and seconds would need to be in separate columns. If they are in one column, then the data need to be parsed in excel and decimal degrees calculated from it
Thanks Jayanta.. PFA excel sheet.
sir this is the excel.
Those dms text strings look well formatted so the convert coordinate notation tool would work on this data.
Thanks a lot .. can you please tell me about that equation??
