You guys will not be receiving support from esri on this as stated in the first couple of posts there are legal constraints applied by Google that will not allow you to use their data outside of their APIs and products. So even if you are able to get this to work you as putting your organization at risk for lawsuits.
Hi Ivan...I would like to incorportate Google maps as well in my Flexviewer... Were you able to get it working? If so, would please share your knowledge and code..nia@miamidade.govThanks in advanceNasif
We are currently using Bing Maps or ERSI online as base maps for our Flexviewer 2.4 app. However, for those regions we are focusing on Google provides most detailed data. We would therefore appreciate to be able to implement Google maps as our base map.How may we implement this. License should not be an issue. what we need is simple help for the technical solution. How would the code line for using Google as a base map in Flexviewer 2.4 look like and where should a license key be located?Any assistance is highly appreciated. I have seen the flex sample by izambakci. May you provide the explanation how this was implemented. We don't need sharing the entire project, just the implementation of Google base map.Thanks,Ivan Baehr,UNOSAT
