I am trying to create a function to zoom to the extent of a layer. I have found a good example here, but my JavaScript skills and knowledge of the JSAPI is just not good enough to cannibalize and shoehorn this into my simple example (I only attempt my hand at it about once every eight months or so). Rather than further bumbling the code (and after seeking additional examples to no avail), I thought I would seek assistance from others much more knowledgeable than I.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>Intro to MapView - Create a 2D map - 4.7</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.7/esri/css/main.css">
<script ></script>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/geometry/support/webMercatorUtils",
"esri/widgets/Search",
"esri/widgets/Locate",
"esri/widgets/Expand",
"esri/layers/TileLayer",
"esri/widgets/LayerList",
"esri/widgets/BasemapGallery",
"dojo/dom",
"dojo/domReady!"
], function(Map, MapView, webMercatorUtils, Search, Locate, Expand, TileLayer, LayerList, BasemapGallery, dom) {
var droneimage1 = new TileLayer({
url: "https://tiles.arcgis.com/tiles/3xOwF6p0r7IHIjfn/arcgis/rest/services/a010002_1/MapServer",
title: "Drone Image"
var map = new Map({
basemap: "streets",
layers: [droneimage1]
var view = new MapView({
container: "viewDiv",
map: map,
zoom: 15,
center: [-103.064, 36.175] // longitude, latitude
function showCoordinates(evt) {
var point = view.toMap({x: evt.x, y: evt.y});
//the map is in web mercator but display coordinates in geographic (lat, long)
var mp = webMercatorUtils.webMercatorToGeographic(point);
//display mouse coordinates
dom.byId("info").innerHTML = mp.x.toFixed(3) + ", " + mp.y.toFixed(3);
view.when(function(){
//after map loads, connect to listen to mouse move & drag events
view.on("pointer-move", showCoordinates);
// create a search widget
var searchWidget = new Search({
view: view
// create the locate widget
var locateBtn = new Locate({
view: view
// Add the locate widget to the top left corner of the view
view.ui.add(locateBtn, {
position: "top-left"
// Add the search widget to the top right corner of the view
view.ui.add(searchWidget, {
position: "top-right"
// create a layer list widget
var layerList = new LayerList({
view: view,
// executes for each ListItem in the LayerList
listItemCreatedFunction: function (event) {
// The event object contains properties of the
// layer in the LayerList widget.
var item = event.item;
// set an action for zooming to the full extent of the layer
item.actionsSections = [[{
title: "Zoom to layer",
className: "esri-icon-zoom-out-fixed",
view.ui.add(layerList, "bottom-left");
// Create a BasemapGallery widget instance and set
// its container to a div element
var basemapGallery = new BasemapGallery({
view: view,
container: document.createElement("div")
// Create an Expand instance and set the content
// property to the DOM node of the basemap gallery widget
// Use an Esri icon font to represent the content inside
// of the Expand widget
var bgExpand = new Expand({
view: view,
content: basemapGallery
// Add the expand instance to the ui
view.ui.add(bgExpand, "top-left");
</script>
</head>
<body>
<div id="viewDiv"></div>
<span id="info" style="position:absolute; right:25px; bottom: 25px; color:#000000; font-size: 12px; z-index:50;"></span>
</body>
</html>
Todd
