i have two on layer click events.
scenario is two show two infotemplates when on layer1 is clicked
when on "A" layer is clicked "B" layer is not fired initially
when i click on "B" layer it is working(area code details information)
now code related to "B" is registered after clicking on it, initially on page load evt it was not registered i guess
Again if i click on "A" layer now both events works(initially it doesn't)
Any suggestions
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta http<SPAN class="operator token">-</SPAN>equiv<SPAN class="operator token">=</SPAN><SPAN class="string token">"Content-Type"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/html; charset=utf-8"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1, maximum-scale=1,user-scalable=no"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Non graphic info window<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.27%2Fesri%2Fcss%2Fesri.css" target="_blank">https://js.arcgis.com/3.27/esri/css/esri.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN>
html<SPAN class="punctuation token">,</SPAN> body<SPAN class="punctuation token">,</SPAN> #map<SPAN class="punctuation token">{</SPAN>
height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.27%2F" target="_blank">https://js.arcgis.com/3.27/</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="keyword token">var</SPAN> map<SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"esri/dijit/PopupTemplate"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"esri/InfoTemplate"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"esri/dijit/Popup"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/domReady!"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>
Map<SPAN class="punctuation token">,</SPAN>PopupTemplate<SPAN class="punctuation token">,</SPAN>FeatureLayer<SPAN class="punctuation token">,</SPAN>InfoTemplate<SPAN class="punctuation token">,</SPAN>PopupMobile
<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> service1 <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fbbb.aaaaa.com%2Farcgis03%2Frest%2Fservices%2Faaaa%2Fbbbb%2FFeatureServer%2F0" target="_blank">http://bbb.aaaaa.com/arcgis03/rest/services/aaaa/bbbb/FeatureServer/0</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> service2 <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fbbb.aaaaa.com%2Farcgis03%2Frest%2Fservices%2Fsbc%2FTerritorry%2FMapServer%2F2" target="_blank">http://bbb.aaaaa.com/arcgis03/rest/services/sbc/Territorry/MapServer/2</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> popup <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">PopupMobile</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> dojo<SPAN class="punctuation token">.</SPAN><SPAN class="token function">create</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"div"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> Ginfotemplate <SPAN class="operator token">=</SPAN> InfoTemplate<SPAN class="punctuation token">;</SPAN>
map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"topo"</SPAN><SPAN class="punctuation token">,</SPAN>
infoWindow<SPAN class="punctuation token">:</SPAN> popup<SPAN class="punctuation token">,</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">87.6298</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">41.8781</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">13</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> popupTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">PopupTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
content<SPAN class="punctuation token">:</SPAN> content1
<SPAN class="keyword token">var</SPAN> popupTemplate2 <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">PopupTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
content<SPAN class="punctuation token">:</SPAN> content2
<SPAN class="keyword token">var</SPAN> layer1 <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN>service1<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
mode<SPAN class="punctuation token">:</SPAN> FeatureLayer<SPAN class="punctuation token">.</SPAN>MODE_AUTO<SPAN class="punctuation token">,</SPAN>
infoTemplate<SPAN class="punctuation token">:</SPAN> popupTemplate<SPAN class="punctuation token">,</SPAN>
outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"opacity"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.9</SPAN>
<SPAN class="keyword token">var</SPAN> Glayer1 <SPAN class="operator token">=</SPAN> layer1<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> layer2 <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN>service2<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
mode<SPAN class="punctuation token">:</SPAN> FeatureLayer<SPAN class="punctuation token">.</SPAN>MODE_SNAPSHOT<SPAN class="punctuation token">,</SPAN>
infoTemplate<SPAN class="punctuation token">:</SPAN> popupTemplate2<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"opacity"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.5</SPAN>
<SPAN class="keyword token">var</SPAN> Glayer2 <SPAN class="operator token">=</SPAN> layer2<SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayers</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>layer2<SPAN class="punctuation token">,</SPAN>layer1<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
layer1<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> idProperty <SPAN class="operator token">=</SPAN> layer1<SPAN class="punctuation token">.</SPAN>objectIdField<SPAN class="punctuation token">,</SPAN>
feature<SPAN class="punctuation token">,</SPAN>
featureId<SPAN class="punctuation token">,</SPAN>
query<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>graphic <SPAN class="operator token">&&</SPAN> evt<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes <SPAN class="operator token">&&</SPAN> evt<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">[</SPAN>idProperty<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
feature <SPAN class="operator token">=</SPAN> evt<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">,</SPAN>
featureId <SPAN class="operator token">=</SPAN> feature<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">[</SPAN>idProperty<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
Glayer1<SPAN class="punctuation token">.</SPAN>infoTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Ginfotemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Title1"</SPAN> <SPAN class="punctuation token">,</SPAN> content1<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
popup<SPAN class="punctuation token">.</SPAN><SPAN class="token function">show</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
layer2<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> idProperty2 <SPAN class="operator token">=</SPAN> layer2<SPAN class="punctuation token">.</SPAN>objectIdField<SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>graphic <SPAN class="operator token">&&</SPAN> evt<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes <SPAN class="operator token">&&</SPAN> evt<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">[</SPAN>idProperty2<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
featureId <SPAN class="operator token">=</SPAN> feature<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">[</SPAN>idProperty2<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
Glayer2<SPAN class="punctuation token">.</SPAN>infoTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Ginfotemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Title2"</SPAN><SPAN class="punctuation token">,</SPAN> content2<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="keyword token">var</SPAN> content1 <SPAN class="operator token">=</SPAN> <SPAN class="string token">"<table class='table'><tr><td>Field1</td><td>${Field1}</td></tr>"</SPAN> <SPAN class="operator token">+</SPAN>
<SPAN class="string token">"</table>"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> content2 <SPAN class="operator token">=</SPAN> <SPAN class="string token">"<table class='table'><tr><td>Teritory</td><td><strong>${Field2}</strong></td></tr>"</SPAN> <SPAN class="operator token">+</SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
