I have a tpk that I authored using ArcGIS Pro 1.4. I am able to open this in ArcMap 10.4.1 with no problems. However, I can't seem to get it to load in a map within Pro!
I locate the tpk within the folder, right click and select 'Add to new map', or 'Add to current map' but nothing happens. No error message, and the layer is not added to any map. Using a 'click and drag' method to try to add to an existing map doesn't work either, whether I drag into the map frame or the Table-of-Contents.
I wondering if the issue is the tpk itself, or something to with Pro. Would be interested to hear if anyone else experiences anything similar.
In ArcMap, I can see the spatial reference is correctly set as WGS 84.
