Jason, There are a few places where you can start. I take it you are using a State Plane gird coordinate system? If so, do you have the current PLSS (GCDB) corner points?The Parcel Editor assumes that all incoming measurements are in local, ground coordinates. Understanding that, you can join these parcels to control points in state plane, essentially establishing a general ground-to-grid conversion. I would take a look at an area that resides near the baseline and meridian intersection of the State Plane coordinate system and start by joining a few parcels that have known connection to section corners and works out from there.Would you like to set up a call to discuss? I'd be more than willing to help you get started.ChrisParcel Editing Team
As a graduate student I've been exploring the conversion of existing legacy paper CSM's into arcmap. I've never worked with parcels or CSM's before so its really a first step situation.Having just started poking around in 10, I see that there is a parcel tool bar as well as cogo. I have no background in either. lolIt seems to me that the help files and tutorials assume users will be EDITING an existing dataset and working with existing parcels shapefiles and databases VS. creating parcels and database from scratch. At this point I'm not sure where to start. Does anybody have some wise advise as to how to get started the correct way?ThanksJP
