We just wonder why the Python toolbox debug menu item disabled? ArcCatalog 10.3.1.
Hi everybody,
sorry to jump in late but here is what I normally do when debugging python toolboxes (it works great!).
How to Debug Python Toolboxes in 3 Easy Steps | ArcGIS Blog
Dan,
Could you please explain what is "the script enabled".
Moving up one level allows us to edit
It is my Python toolbox. Just created.
Well, it appears you have the script enabled and it can't be put into edit mode.
Which leaves, moving up one level and see if selecting the actual toolbox will enable you to edit it first.
If neither of those work, I would try this when the toolbox is added to arctoolbox rather than doing it from arccatalog.
And my final question, was whether it was a toolbox that was yours, or you got from somewhere else, that might be in a higher version, but encrypted. I know that you were using arccatalog 10.3, but the source/origin of the toolbox wasn't obvious.
Addendum
Click on Properties and report what is there as well. I am assuming that the script actually exists from the looks of it, but that is hidden.
Thank you Dan,
The current version is 10.3.1
My question - how to enable "Debug" menu item?
Unfortunately, I cannot see any explanation in links you provided.
In arcmap 10.6 Editing a Python toolbox
in arcmap 10.3 Editing a Python toolbox
But in newer versions you can Encrypt a Python toolbox
Is there a chance that you have a new version of the toolbox?
