how to give customized values in attributes while editing
var newGraphic = new Graphic(point2, null, newAttributes);
You can create your own attributes object and set the attributes at any time:
<SPAN class="keyword token">var</SPAN> attrobj <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> x<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> y<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> comment<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> newGraphic<SPAN class="punctuation token">.</SPAN>attributes <SPAN class="operator token">=</SPAN> attrobj<SPAN class="punctuation token">;</SPAN> newGraphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>id <SPAN class="operator token">=</SPAN> myIDval<SPAN class="punctuation token">;</SPAN> newGraphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>x <SPAN class="operator token">=</SPAN> myXval<SPAN class="punctuation token">;</SPAN> newGraphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>y <SPAN class="operator token">=</SPAN> myYval<SPAN class="punctuation token">;</SPAN> newGraphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>comment <SPAN class="operator token">=</SPAN> myComment<SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
thank u fc basson it worked
No, just the graphic's attributes. You'll still need to push the values through to the editable feature class.
will that reflect into database
