Hello wikgrebc, I am using a very similar dataset and wondered if you can recall (4 years after you posted!) and share any insights. I have >9000 observation points, with 1092 sightings, so mostly zero's. From my literature search, I've narrowed it down to try Empirical Bayesian Kriging using geostatistical analyst (because I don't have time to learn to use R software, which is often mentioned in literature review for kriging with a poisson distribution). I've built some kriging models but the standardized mean and RMS says NaN. I've just tried removing all datapoints with a zero and building from that dataset, it helped with the NaN problem, but I'm not sure this is statistically justifiable. Any insights you might have are appreciated. These are sightings of a rare bird species, where a positive sighting is a count between 1-4 because the data have been rolled into centroids of a grid applied to the study area.
I don't have any good solutions for the zero-inflation problem (other than, potentially, the one posted by jevans), but I can shed some light on the NaN issue. Empirical Bayesian Kriging computes local models based on subsets of the data. However, if a subset is composed entirely of a constant value (in this case, zero), the kriging equations cannot actually be solved (the algorithm will attempt to invert something that cannot be inverted). We put in a special exception when this happens; the subset will predict a constant value everywhere in the subset with a standard error value of zero. This alleviates the problem of a single subset preventing you from getting any output at all, but it has the size effect of making it impossible to calculate many crossvalidation statistics. This is why many of them will report NaN (Not a Number) when this happens.
Thank you EKrause-esristaff for this explanation. It helps. I'm not sure if this too large a question to pose, but I will ask anyway. Would you say that using Empirical Bayesian Kriging on zero-inflated data creates an invalid model? I have downloaded the articles suggested above and will continue to investigate that route but for my purposes I was optimistically hoping EBK might be justifiable.
Doing any kind of kriging (other than fancy things like double kriging, as jevans noted) is going to be very questionable with high degrees of zero-inflation. Technically, zero-inflation does not mean that using kriging is "invalid," but the issue is pretty complicated. In theory, kriging can be performed on just about any data distribution, even ones with zero inflation. However, to do this correctly, you need to be able to accurately estimate the semivariogram with the typical covariance functions that are provided. In practice, fitting an accurate semivariogram for strange data distributions is not something that I would recommend because I don't know of a reliable methodology to do it. And the covariance models that are supported in Geostatistical Analyst are very, very unlikely to be able to estimate an accurate semivariogram for data with large zero-inflation.
