Geoprocessing Service Only Runs Once
I am trying to publish an ArcGIS geoprocessing service in 10.2 I have a script setup that will run multiple times through Pycharm, but when I run it in ArcGIS it will run once and return this error:
File "C:\Users\\Desktop\git\GeoprocessingService.py", line 477, in <module>
main()
File "C:\Users\Desktop\git\GeoprocessingService.py", line 372, in main
cur)
File "C:\Users\Desktop/git\GeoprocessingService.py", line 136, in value_query
results = cur.fetchall()
File "C:\Python27\ArcGIS10.2\lib\site-packages\psycopg2\extras.py", line 81, in fetchall
res = super(DictCursorBase, self).fetchall()
File "C:\Python27\ArcGIS10.2\Lib\decimal.py", line 543, in __new__
m = _parser(value.strip())
TypeError: 'NoneType' object is not callable
Failed to execute (Script).
The script itself is 800 lines, but here is the query I have been running that errors out:
def value_query(id_field, id, value_fields, start_date, end_date, date_field, table, cur):
query2 = "SELECT "
for field in value_fields:
query2 += "NULLIF({0}, '-999')::NUMERIC(6,2),".format(field)
query2 += "{0} " \
"FROM {1} " \
"WHERE {2} = '{3}' AND {0} BETWEEN '{4}' AND '{5}' " \
"ORDER BY {0} ASC;".format(date_field, table, id_field, id, start_date, end_date)
#print "This is Query:"
#print query
arcpy.AddMessage("{0}".format(query2))
cur.execute(query2)
#print "These are value query results:\n\n {0}".format(results)
return results
Like I said it runs once in ArcGIS then errors out. However, if I close Arc completely and run the exact same script again, it runs once then stops. I feel like there may be some sort of caching or something that Arc does, but am completely stumped.
