I meet the same error with you. Luckily,I found solutions at website. Maybe you have solved your problem, wish my answer can help others who meet the same error.
i have the same problem with arcgis10.3 and two years ago again the same problem with arcgis10. i cant solve this. i tried all advices in here but the same error again and again. i am using student licence with full extensions. cracked arcgis9.3 still can solve without any problem why arcgis10 and 10.3 always give the same error. Also when i did my first export, it was worked. there was no problem but for the second project it failed. Anyway i give an ss below. if there is anyone who can solve the problem please help me i dont want to use again cracked arcgis 9.3
Does saving closer to this disk root mean saving closer to the drive itself, for example, if saving to a C:\ drive saving as close as possible to the C:\?
Using ArcInfo 10 and GeoRAS 10 I am attempting to create my export .xml and .sdf files to create my model. I have gone through the process with the tutorial in the users manual and it worked fine. Now that I am using my actual project data, I am getting an error when I try to export it. It says "Failed to create intermediate ESRI XML file!" I have attached the output file that runs. I had no errors when creating my data, just when I go to export it. Thanks in advance for your ideas.
I don't use GeoRAS at all. However, when I look at your Output.xlsx file, I see many "Target location not specified..." messages. From my experience in Arc Hydro, the "Target" is the file location ArcMap is trying to create the file in. Look for the where GeoRAS defines the output files and make sure the directory and filename are correct. I've had Arc Hydro keep the Target from the previous Arc Hydro project and had to correct it before certain functions would work.I Googled "GeoRAS target" and found ftp://ftp-fc.sc.egov.usda.gov/SD/www/Technical/Engineering/Hydrology/Geo_Ras_xsec_instructions.pdf In this I searched for "target" and found that they use the ApUtilities menu also. Look under the ApUtilities menu to Set the target locations. Also, in Arc Hydro, there is an option to reset the target loations. GeoRAS might have that too.
So I decided to re-start and the second time around it worked fine. I had some crashes the first time, so maybe that just created some sort of bug/error? Anyway, it's all good now.
