i have two line,part of which covered each other,i need get the covered part
thanks
you mean the intersection, right? see here: ArcObjects Help for .NET developers (ITopologicalOperator.Intersect)
is ITopologicalOperator.Intersect can used in 3Dimension?
i got an argument exception,when set esriGeometry3Dimension
thanks,you are right,i did not think about it carefully
thanks a lot
do you see the graphic in the link to the documentation for ITopologicalOperator.Intersect?
I guess the example with the two lines shows the solution for your problem... or i don't get it
thanks for your reply,actually,it is not the intersection
i mean,some parts of two line,in the spatial,are almost same
i need get the same part
