What is the best way to have the map watch for changes a data store. (on change do something inside the map).
I have a map as a component which I'd like to bind its definition query to something set in the store. I'm doing it this way as the users interact with a side panel (which IS NOT in the map), so I'm having it update a value in the store via mutations. From there I'd like the map to watch for changes to that value and simply update a layers definition query.
I can access the data store perfectly fine from within the map this.$store.state.DefinitionQuery gives me the value I want. But when I try to set the watchUtils watch that value is fires multiple promise and other errors.
I'm not committed to this data structure so if anyone has a better way to have the map respond to changes in other components (**not a widget in the map***) I'm open to the ideas as well.
I've attached an example of the map component I've got so far. Right now I'm just trying to make it log on a change, but once I figure out the onChange event I'll bind the pointLayer.definitionQuery to it.
