Hello,I'm getting the following exception thrown when trying to run a Geoprocessing tool:"Error HRESULT E_FAIL has been returned from a call to a COM component." at ESRI.ArcGIS.Geoprocessing.GeoProcessorClass.Execute(String Name, IVariantArray ipValues, ITrackCancel pTrackCancel) at ESRI.ArcGIS.Geoprocessor.Geoprocessor.ExecuteInner(IGPProcess process, ITrackCancel trackCancel, IGeoProcessor igp, IVariantArray iva) at ESRI.ArcGIS.Geoprocessor.Geoprocessor.Execute(IGPProcess process, ITrackCancel trackCancel) at GisViewer.GeoprocessingDialog.<RunSelectedTool>b__0() in C:\TASource\Source\MRA\PACS.NET-1.0\GisViewer\Dialogs\GeoprocessingDialog.cs:line 154
The code I'm using is: private IFeatureLayer GetSelectedLayers() { foreach (String item in featureList.CheckedItems) { for (int i = 0; i < synchronizer.MapControl.LayerCount; ++i) { var layer = synchronizer.MapControl.get_Layer(i); if (layer.Name == item) { return layer as IFeatureLayer; } } } return null; } private IGPProcess GetSelectedTool() { var selectedTool = (GeoprocessorCommand.Command)toolCombo.SelectedItem; if (selectedTool == GeoprocessorCommand.Command.Buffer) { var tool = new ESRI.ArcGIS.AnalysisTools.Buffer(); tool.in_features = GetSelectedLayers(); tool.out_feature_class = outputText.Text; return tool; } else if (selectedTool == GeoprocessorCommand.Command.Clip) { var tool = new ESRI.ArcGIS.AnalysisTools.Clip(); return tool; } else if (selectedTool == GeoprocessorCommand.Command.Dissolve) { //var tool = new ESRI.ArcGIS.AnalysisTools. //return tool; } else if (selectedTool == GeoprocessorCommand.Command.Intersect) { var tool = new ESRI.ArcGIS.AnalysisTools.Intersect(); return tool; } else if (selectedTool == GeoprocessorCommand.Command.Merge) { //var tool = new ESRI.ArcGIS.AnalysisTools //return tool; } else if (selectedTool == GeoprocessorCommand.Command.Union) { var tool = new ESRI.ArcGIS.AnalysisTools.Union(); return tool; } return null; } private void RunSelectedTool() { new Thread(new ThreadStart( delegate() { var processor = new Geoprocessor(); var tool = GetSelectedTool(); if (tool != null) { try { var results = (IGeoProcessorResult)processor.Execute(tool, null); if (results.Status == ESRI.ArcGIS.esriSystem.esriJobStatus.esriJobSucceeded) { for (int i = 0; i < results.OutputCount; ++i) { var outputVal = results.GetOutput(i); if (outputVal is DEFeatureClass) { } } } } catch (Exception) { MessageBox.Show("There was an error while running the geoprocessor", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error); } } } )).Start(); }I'm only testing the Buffer tool currently. I've checked, and the tool has both the in_features and out_feature_class assigned correctly before running the process. Any clues?Thanks,George Faraj
