I'm trying to find an add-in that allows me to enter a parcel#, select, then zoom to that parcel. I have seen "zoom to attribute" examples but nothing that allows me to enter parcel numbers. The add-in would be used by me to zoom to the parcel without having to open attribute table find the parcel number (out of thousands) then zoom to.This is the code I have used, which selects all the parcels and then zooms to extent the layer name is "Parcel_Link" and the Field that holds the parcel number is PIN mxd = arcpy.mapping.MapDocument('CURRENT')... df = arcpy.mapping.ListDataFrames(mxd, "Layers") [0]... Parcel_Link = arcpy.mapping.ListLayers('CURRENT', Parcel_Link, df)[0]... whereClause = "PIN ='%s'" % Parcel_Link... arcpy.SelectLayerByAttribute_management("Parcel_Link", "NEW_SELECTION", whereClause)... df.extent = Parcel_Link.getSelectedExtent(True)... df.scale *= 1.5... arcpy.RefreshActiveView()Any input would be niceThanksJoby
import arcpy arcpy.AddMessage("Starting") pu = arcpy.GetParameterAsText(0) arcpy.AddMessage(pu) mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd, "Main Map")[0] lyr = arcpy.mapping.ListLayers(mxd, "PLANNING UNIT", df)[0] arcpy.AddMessage(lyr.name) expression = "PLANNINGUNIT = '"+pu+"'" arcpy.AddMessage(expression) arcpy.SelectLayerByAttribute_management(lyr,"NEW_SELECTION",expression) df.extent = lyr.getSelectedExtent() df.scale = df.scale*1.1 for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT", "PU"): if elm.name == "PU": elm.text = (pu) arcpy.SelectLayerByAttribute_management(lyr,"CLEAR_SELECTION") arcpy.RefreshActiveView() arcpy.AddMessage("Completed")
I hear your frustration, i don't understand why ESRI is not going to be using VBA anymore.
