Hey Jennifer, I tried to set binding to a feature datagrid at run-time through code-behind. I took your suggestion but the binding set seems not working because the datagrid disapear. Initially I bind it with a feature layer but at run time I need re-set the binding to other layers. Below is my code: //binding feature datagrid to target layer Binding bMap = new Binding("bMap"); bMap.Source = MyMap; Binding bLayer = new Binding("bLayer"); bLayer.Source = MyMap.Layers["RegionLayer"]; MyDataGrid.SetBinding(FeatureDataGrid.MapProperty, bMap); MyDataGrid.SetBinding(FeatureDataGrid.GraphicsLayerProperty, bLayer);Initial setting for feature datagrid in XAML:<esri:FeatureDataGrid x:Name="MyDataGrid" Background="White" Map="{Binding ElementName=MyMap}" GraphicsLayer="{Binding ElementName=MyMap, Path=Layers.[PPP_StateLayer]}" />Any idea what's wrong?
MyDataGrid.Map = MyMap; MyDataGrid.GraphicsLayer = MyMap.Layers["RegionLayer"];
Binding bMap = new Binding("bMap"); Binding bLayer = new Binding("bLayer");
Binding bMap = new Binding(""); Binding bLayer = new Binding(""); bLayer.Source = MyMap.Layers["RegionLayer"];
You can look at the XAML code in this sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#QueryRelatedRecords to bind to the attributes. You can set ItemsSource in code or in XAML, I believe it is something like this:ItemsSource="{Binding Graphics}" DataContext="{Binding ElementName=MyMap, Path=Layers[MyLayerId]}".If you are using FeatureDataGrid, this is a good example: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#FeatureDataGrid
If each row corresponds to a graphic, you will have access to the graphic.Attributes. I suggest you look into the Related Tables sample, specifically this event handler in code-behind: SelectedWellsTreeView_SelectedItemChanged
