I would like to know if there is a way to do the equivalent of MapView.ExportImageAsync using sdk.net 10.2.7 ? We have to display wmts layers in our application and hence cannot switch to the new release.
Thanks!
I did this once by exporting the canvas, not perfect but it might get the job done for you. I adapted this from here: WPF Diagramming. Saving you canvas to image, XPS document or raw Xaml. | Denis Vuyka
I used a "scale" of 2 for what I was doing, note that it is not the "Map Scale" the method just exports exactly what is visible in the canvas. Hope this helps.
<SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">static</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">ExportToPng</SPAN><SPAN class="punctuation token">(</SPAN>Uri path<SPAN class="punctuation token">,</SPAN> MapView surface<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">int</SPAN> scale<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>path <SPAN class="operator token">==</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Save current canvas transform</SPAN> Transform transform <SPAN class="operator token">=</SPAN> surface<SPAN class="punctuation token">.</SPAN>LayoutTransform<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// reset current transform (in case it is scaled or rotated)</SPAN> surface<SPAN class="punctuation token">.</SPAN>LayoutTransform <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Get the size of canvas</SPAN> Size size <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Size</SPAN><SPAN class="punctuation token">(</SPAN>surface<SPAN class="punctuation token">.</SPAN>ActualWidth<SPAN class="punctuation token">,</SPAN> surface<SPAN class="punctuation token">.</SPAN>ActualHeight<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Measure and arrange the surface</SPAN> <SPAN class="comment token">// VERY IMPORTANT</SPAN> surface<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Measure</SPAN><SPAN class="punctuation token">(</SPAN>size<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> surface<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Arrange</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Rect</SPAN><SPAN class="punctuation token">(</SPAN>size<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Create a render bitmap and push the surface to it</SPAN> RenderTargetBitmap renderBitmap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">RenderTargetBitmap</SPAN><SPAN class="punctuation token">(</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">int</SPAN><SPAN class="punctuation token">)</SPAN>size<SPAN class="punctuation token">.</SPAN>Width <SPAN class="operator token">*</SPAN> scale<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">int</SPAN><SPAN class="punctuation token">)</SPAN>size<SPAN class="punctuation token">.</SPAN>Height <SPAN class="operator token">*</SPAN> scale<SPAN class="punctuation token">,</SPAN> 96d <SPAN class="operator token">*</SPAN> scale<SPAN class="punctuation token">,</SPAN> 96d <SPAN class="operator token">*</SPAN> scale<SPAN class="punctuation token">,</SPAN> PixelFormats<SPAN class="punctuation token">.</SPAN>Pbgra32<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> renderBitmap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Render</SPAN><SPAN class="punctuation token">(</SPAN>surface<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Create a file stream for saving image</SPAN> <SPAN class="keyword token">using</SPAN> <SPAN class="punctuation token">(</SPAN>FileStream outStream <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FileStream</SPAN><SPAN class="punctuation token">(</SPAN>path<SPAN class="punctuation token">.</SPAN>LocalPath<SPAN class="punctuation token">,</SPAN> FileMode<SPAN class="punctuation token">.</SPAN>Create<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// Use png encoder for our data</SPAN> PngBitmapEncoder encoder <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">PngBitmapEncoder</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// push the rendered bitmap to it</SPAN> encoder<SPAN class="punctuation token">.</SPAN>Frames<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Add</SPAN><SPAN class="punctuation token">(</SPAN>BitmapFrame<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Create</SPAN><SPAN class="punctuation token">(</SPAN>renderBitmap<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// save the data to the stream</SPAN> encoder<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Save</SPAN><SPAN class="punctuation token">(</SPAN>outStream<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="comment token">// Restore previously saved layout</SPAN> surface<SPAN class="punctuation token">.</SPAN>LayoutTransform <SPAN class="operator token">=</SPAN> transform<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thanks. It works great.
