What happened to the setAttributeValue and removeAttribute methods on the Class Graphic? The only way I see to set attributes is to include them when instantiating the graphic. In my app, I draw a polygon in a graphics layer and then have a popup dialog box asking the user to enter info which will populate the attributes. So my graphic exist before having attributes. How do I populate the attributes after I already instantiated the graphic? I tried updateGraphic. I used the constructor that allow you to assign an ID. I then created another graphic with attributes and used the updateGraphic method, but itdid not work. I found that my first graphic did did not contain the graphic ID I assigned, but some random one. How else can I do this?Why was setAttributeValue and removeAttribute methods removed? Seems to make sense to be able to have such methods.
mMapView.setOnLongPressListener(new OnLongPressListener() { private static final long serialVersionUID = 1L; @Override public void onLongPress(float x, float y) { int[] guids = gLayer.getGraphicIDs(x, y, 10); if(guids.length != 0){ Graphic gr = gLayer.getGraphic(guids[0]); int uid = gr.getUid(); Map<String,Object> attr = gr.getAttributes(); attr.put("name", "Test"); gLayer.updateGraphic(uid, attr); Log.d("Test", "Graphic attr update name = "+ gr.getAttributeValue("name")); } }
