I have arcgis 10.5 desktop on my windows 10 machine. I tried uninstalling arcgis 10.5 and python and reinstalling but the problem persists. Any ideas on how to fix?
That's not quite the problem. I can not even open the search window (either by clicking on the icon or going under windows>Search or the shortcut ctrl+F). I tried option b (since I can't get to the search options under option a) and still could not open the search window after renaming the catid folder.
Check Problem: The Search window in ArcMap does not return any results .
Are you facing the same issue?
Unchecking the background geoprocessing worked and now the program has stopped crashing. However, I still can not use the Search window in arcmap though it does open in arccatalog. When I click on the search window nothing happens.
If the solution steps provided by Rebecca doesn't work, you could disable background geoprocessing. Sometimes, it causes the issue as well.
Foreground and background processing—Help | ArcGIS for Desktop
Also I have seen a fresh install of Windows 10 gives fewer issues with ArcGIS than those upgraded from older versions.
Start with steps in this https://community.esri.com/docs/DOC-2121?sr=search&searchId=cd6a211a-a246-4fe0-8698-e9e9f38eaf2d&searchIndex=0 It's amazing how those steps can fix many "now it crashes desktop" issues.
Windows 10 can have a few other quirks, but see if the above works first.
