I have a popup display that reads a datetime field in a csv file. The field (Discovered Date) displays in Firefox and IE but not Chrome. Any idea how I would go about fixing this?
Here is the map in question. Click any pin to see the popup in action. Must be in Chrome to reproduce the bug.
Status Map | AAF - Agriculture and Forestry
Also, how do I move the region overlays to the back. Built in arcgis online.
Thanks.
Trent,
That sure is odd. I was able to reproduce the issue like you stated. Can you share a link to your original web map in ArcGIS Online?
Here is the link to the ArcGis Online map: http://www.arcgis.com/home/webmap/viewer.html?webmap=1900cfe14e964216802ce033256b6cc0
Huh. Same issue. I wonder if the most recent update of Chrome is causing issues for AGOL. My current version is:
Version 56.0.2924.87
This may be worth reporting a bug to Esri about.
Thanks for your help on the issue Adrian. I created a comment here:
https://blogs.esri.com/esri/supportcenter/2007/09/14/bugs-online-is-here/#comment-1936
I think my question is still in moderator approval status. Should be up shortly I'm thinking.
Not sure if that's the right place or not. Let me know if you have another place you think I should report it to.
Trent
At this point it might be best to contact your local esri rep about this and see if they can reproduce this. Unless someone on this board will log a support ticket for you (which happens but not often).
I can get a Support Case created. Could you direct message me your contact information (email and phone) so an Analyst can reach out to you directly.
Mrinvertigo@hotmail.com is my email. 780 802-3479.
Get Outlook for Android<https://aka.ms/ghei36>
Hi Katie Cullen do you have a resolution for this? We have users experiencing a similar issue with Chrome. Please and thanks...Meg
Rex Turgano
I wasn't able to reproduce this. Can you open a case with Support? It may be specific to the data.
thx for the quick reply Katie... we'll open a case with esri support...cheers, Meg
