How do I add multiple graphics (side by side) on the same point (rather than on top of each other) in ArcGIS .Net SDK.
Thanks, Billyson
You can use OffsetX property of MarkerSymbol. In the sample below, graphics share the same geometry, which is the tapped location, but x offset is added to the symbol for the succeeding graphics.
xmlns:esri="http://schemas.esri.com/arcgis/runtime/2013"> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Grid</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">esri:</SPAN>MapView</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">x:</SPAN>Name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>MyMapView<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">GeoViewTapped</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>MyMapView_GeoViewTapped<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">/></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Grid</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
<SPAN class="keyword token">public</SPAN> <SPAN class="token function">MainWindow</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="token function">InitializeComponent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> MyMapView<SPAN class="punctuation token">.</SPAN>Map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN>Basemap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateTopographic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> MyMapView<SPAN class="punctuation token">.</SPAN>GraphicsOverlays<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsOverlay</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">private</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">MyMapView_GeoViewTapped</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">object</SPAN> sender<SPAN class="punctuation token">,</SPAN> GeoViewInputEventArgs e<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> mp <SPAN class="operator token">=</SPAN> e<SPAN class="punctuation token">.</SPAN>Location<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> overlay <SPAN class="operator token">=</SPAN> MyMapView<SPAN class="punctuation token">.</SPAN>GraphicsOverlays<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">int</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> <SPAN class="number token">5</SPAN><SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> sms <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleMarkerSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleMarkerSymbolStyle<SPAN class="punctuation token">.</SPAN>Circle<SPAN class="punctuation token">,</SPAN> Colors<SPAN class="punctuation token">.</SPAN>Red<SPAN class="punctuation token">,</SPAN> 10d<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> sms<SPAN class="punctuation token">.</SPAN>OffsetX <SPAN class="operator token">=</SPAN> sms<SPAN class="punctuation token">.</SPAN>Size <SPAN class="operator token">*</SPAN> i<SPAN class="punctuation token">;</SPAN> overlay<SPAN class="punctuation token">.</SPAN>Graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN>mp<SPAN class="punctuation token">,</SPAN> sms<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thanks for the reply.
How do I do this if I will use PictureMarkerSymbol?
Properties OffsetX and OffsetY are also available for PicturemarkerSymbol. You can use the properties same way for PictureMarkerSymbol also.
