I've written a script. that uses the field calculator to create a value for a new field, "TotGroupField". This field value is = to Field1+Field2+Field3....I'm getting the following error:Traceback (most recent call last): File RCW\Code\ForLoop.py", line 99, in <module> GrpExpression = sum([GrpField1New+GrpField2New+GrpField3New+GrpField4New+GrpField5New]) TypeError: unsupported operand type(s) for +: 'int' and 'str'
Script:#Create Feature Layers from Feature Classes parcelsFC = "ACUB_3mile.shp" parcelsFL = outName(parcelsFC,"_Layer") CbuffersFL = outName(CBuffersFC,"_Layer") arcpy.MakeFeatureLayer_management(parcelsFC, parcelsFL) arcpy.MakeFeatureLayer_management(CBuffersFC, CbuffersFL) TotalGrpField = "TotGrpCalc" #Temp - will be deleted TotalPBGField = "TotaBGCalc" #Temp - Will be deleted AvgGrpField= "AvgGrp0812" #Make into user input AvgPBGField= "AvgPBG0812" #Make into user input arcpy.AddField_management(CbuffersFL,TotalGrpField,"DOUBLE") print arcpy.GetMessages(),"\n" arcpy.AddField_management(CbuffersFL,TotalPBGField,"DOUBLE") print arcpy.GetMessages(),"\n" arcpy.AddField_management(CbuffersFL,AvgGrpField, "DOUBLE") print arcpy.GetMessages(),"\n" arcpy.AddField_management(CbuffersFL,AvgPBGField,"DOUBLE") print arcpy.GetMessages(),"\n" #Join All Nest Files Table to new selected buffer file. This table was preproccessed and made into a single dbf table (joined by cluster key) showing groupsize and PBG by year. #A column was created called TotalSize and Total PGB for each cluster. The total column will be used to help calculate the average group size/average pbg size for RCW clusters #whose 3-mile dispersal buffer intersect with each parcel. #This means this table will have to be updated manually every year unless written into the script. #This join is used to calculate criteria 2 and 3. #Input for a join must be a layer NestFiles="/RCW/Nest Data/Edited Nest Data/Nest_All.dbf" arcpy.AddJoin_management(CbuffersFL,"Cluster_ke",NestFiles,"Key12","KEEP_ALL") print arcpy.GetMessages(),"\n" GrpField1= "Nest_All.GrpSz08" #User selects field GrpField2= "Nest_All.GrpSz09" #User selects field GrpField3= "Nest_All.GrpSz10" #User selects field GrpField4= "Nest_All.GrpSz11" #User Selects field GrpField5= "Nest_All.GrpSz12" #User selects field GrpField1New= "!"+GrpField1+"!" GrpField2New= "!"+GrpField2+"!" GrpField3New= "!"+GrpField3+"!" GrpField4New= "!"+GrpField4+"!" GrpField5New= "!"+GrpField5+"!" GrpExpression = sum([GrpField1New+GrpField2New+GrpField3New+GrpField4New+GrpField5New]) arcpy.CalculateField_management(CbuffersFL,TotalGrpField,GrpExpression,"PYTHON") print arcpy.GetMessages()
