//get layers in message group layer Layer[] layers = mgl.getLayers(); System.out.println("there are layers : " + layers.length); //go through the layers in the message group layer to do a hit test on each one: for(Layer gLayer : layers) { System.out.println("Layer name = " + gLayer.getName()); System.out.println("--------------------------------"); //cast to graphics layer GraphicsLayer gl = (GraphicsLayer) gLayer; int[] all_graphics = gl.getGraphicIDs(); System.out.println("total graphics = " + all_graphics.length); int[] ids = gl.getGraphicIDs((float)arg0.getX(),(float) arg0.getY(), 5, 4000); if (ids.length > 0) { System.out.println("hit result with " + ids.length); gl.setSelectionIDs(ids, true); } }
map clicked at -156543.03392799944,626172.1357119977 there are layers : 3 Layer name = position_reports_Lines -------------------------------- total graphics = 4001 hit result with 4000 Layer name = position_reports -------------------------------- total graphics = 4001 hit result with 4000 Layer name = chemlights -------------------------------- total graphics = 4000 hit result with 4000
getGraphicIDspublic int[] getGraphicIDs(float x, float y, int tolerance)Finds the graphics near the supplied x,y in pixels. Both visible and invisible graphics are returned. The graphics must have been through a Map draw cycle before they can be found. Parameters:x - the x coordinates of the point for searching.y - the y coordinates of the point for searching.tolerance - the search tolerance in pixels Returns:the first 10 graphics within the search tolerance.
for (GraphicsLayer layer : this.graphicsLayers) { layer.clearSelection(); // Get the maximum number of graphics per layer within 5 pixels of the X and Y of // the selected mouse click. int[] hitGraphicsIDs = layer.getGraphicIDs(mouseEvent.getX(), mouseEvent.getY(), 5, layer.getNumberOfGraphics()); layer.setSelectionIDs(hitGraphicsIDs, true); try { for (int id : hitGraphicsIDs) { this.graphicsQueue.put(layer.getGraphic(id)); } } catch (InterruptedException e) { // TODO Log e.printStackTrace(); break; } }
List<Pair<Message> selectedMgs = new ArrayList<Message>(); for (Graphic graph : graphics) { MessageProcessor mp = messageGroupLayer.getMessageProcessor(); Message msg = mp.createMessageFrom(graph); if (msg != null) selectedMgs.add(msg); }
Graphic graph = messageProcessor().getGraphic(value.getID()); for (Layer layer : symbolLayer.getLayers()) { GraphicsLayer gLayer = (GraphicsLayer)layer; if ((gLayer.getGraphic(graph.getUid()) != null)) { // TODO: Also bring layer to front!! gLayer.bringToFront(graph.getUid()); } }
