symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0, 255, 255]), 5), new Color([255, 255, 0, 0.25]) ); psymbol = new SimpleMarkerSymbol( SimpleMarkerSymbol.STYLE_CIRCLE, 8, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0, 255, 255]), 8), new Color([255, 255, 0, 0.25]) ); function featureZoom(feature) { map.graphics.clear(); ftype = feature.geometry.type; //console.log(feature); if(ftype == "point") { var pt = feature.geometry; var factor = 1; //some factor for converting point to extent var extent = new esri.geometry.Extent(pt.x - factor, pt.y - factor, pt.x + factor, pt.y + factor, pt.spatialReference); map.setExtent(extent.expand(60)); // change this control the zoom showFeature(feature); } else { var fExtent = feature.geometry.getExtent().expand(3); map.setExtent(fExtent); showFeature(feature); } } function showFeature (feature) { map.graphics.clear(); ftype = feature.geometry.type; if(ftype == "point") { feature.setSymbol(psymbol) setTimeout(function(){map.graphics.clear()}, 3000); } else { feature.setSymbol(symbol); setTimeout(function(){map.graphics.clear()}, 3000); } map.graphics.add(feature); }
/***** this would be in your function to create the infowindow ****/ // "results" would be the response from your query StFeatures = results.features; StResults = {displayFieldName: null, features:[]}; for (var i = 0; i < scount; i++) { var sResult = StFeatures; //alert(sResult); if (!StResults.displayFieldName){ StResults.displayFieldName = sResult.displayFieldName } StResults.features.push(sResult); } var stlist = streetList(StResults); // create list to populate the div $("#stlist").html(stlist); //jQuery to fill div with id stlist with the table... can use arcgis function for this also $("#stlist").show("slow"); //jQUery to show the datagrid which is hidden by default /******* End ******/ function streetList(results) { var template = ""; var sn = results.features; template = "<i>Streets Found: " + sn.length + "</i>"; template += "<table border='1'>"; template += "<tr>" template += "</tr>"; for (var i = 0, il = sn.length; i < il; i++) { template += "<tr>"; template += "<td>"+ sn.attributes["FULLADDRESS"] +"</td>"; template += '<td><a href="#" onclick="featureZoom(StResults.features['+ i +']); return false;">(Zoom To)</a></td>'; template += "</tr>"; } template += "</table>"; return template; } function showFeature (feature) { map.graphics.clear(); ftype = feature.geometry.type; if(ftype == "point") { feature.setSymbol(psymbol) setTimeout(function(){map.graphics.clear()}, 3000); } else { feature.setSymbol(symbol); setTimeout(function(){map.graphics.clear()}, 3000); } map.graphics.add(feature); } function featureZoom(feature) { map.graphics.clear(); ftype = feature.geometry.type; //console.log(result); if(ftype == "point") { var pt = feature.geometry; var factor = 1; //some factor for converting point to extent var extent = new esri.geometry.Extent(pt.x - factor, pt.y - factor, pt.x + factor, pt.y + factor, pt.spatialReference); map.setExtent(extent.expand(60)); showFeature(feature); } else { var fExtent = feature.geometry.getExtent().expand(3); map.setExtent(fExtent); showFeature(feature); } }
