<?xml version="1.0" encoding="utf-8"?> <!-- /////////////////////////////////////////////////////////////////////////// // Written by Micheal W. Smith // // Aug 15, 2013 // This Widget is meant to read the URL, parse for a specific parameter (facility or premise) and a unique id // The result is zoomed, centered and marked with a point. // /////////////////////////////////////////////////////////////////////////// --> <viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:Search="widgets.Search.*" xmlns:viewer="com.esri.viewer.*" xmlns:esri="http://www.esri.com/2008/ags" xmlns:components="com.esri.viewer.components.*" creationComplete="basewidget_widgetConfigLoaded()"> <fx:Script> <![CDATA[ import com.esri.ags.FeatureSet; import com.esri.ags.Graphic; import com.esri.ags.geometry.MapPoint; import com.esri.ags.layers.GraphicsLayer; import com.esri.viewer.ViewerContainer; import mx.controls.Alert; import mx.rpc.AsyncResponder; [Bindable] public var UniqueID:String = "000000"; private var zoomScale:Number = 10000; private var graphicsLayer:GraphicsLayer; private function basewidget_widgetConfigLoaded():void { var layer:String =""; if(ViewerContainer.urlConfigParams.premise != null){ layer="premise"; UniqueID = ViewerContainer.urlConfigParams.premise; queryPremise.execute(queryPoint, new AsyncResponder(onResult, onFault)); } if(ViewerContainer.urlConfigParams.facility != null){ layer="facility"; UniqueID = ViewerContainer.urlConfigParams.ViewerContainer.urlConfigParams.facility; queryFacility.execute(queryPoint, new AsyncResponder(onResult, onFault)); } function onResult(featureSet:FeatureSet, token:Object = null):void { if (featureSet.features.length == 0) { Alert.show("No mapable items found. Please try again."); } else { map.scale = zoomScale; map.centerAt(featureSet.features[0].geometry as MapPoint); var myGraphicMarker:Graphic = featureSet.features[0] as Graphic; myGraphicMarker.symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND, 22, 0x009933); graphicsLayer = new GraphicsLayer(); graphicsLayer.add(myGraphicMarker); //adding the graphics layer to the map map.addLayer(graphicsLayer); } } function onFault(info:Object, token:Object = null):void { Alert.show(info.toString()); } } ]]> </fx:Script> <fx:Declarations> <!-- Symbol for Query Result as Point --> <esri:SimpleMarkerSymbol id="sfs" alpha="36" color="Black"/> <!-- Layer with Premises --> <esri:QueryTask id="queryPremise" url="http://atlantis:6080/arcgis/rest/services/SearchTest/MapServer/0"/> <esri:QueryTask id="queryFacility" url="http://atlantis:6080/arcgis/rest/services/SearchTest/MapServer/3"/> <esri:Query id="queryPoint" outSpatialReference="{map.spatialReference}" returnGeometry="true" text="{UniqueID}"> </esri:Query> </fx:Declarations> </viewer:BaseWidget>
function onResult(featureSet:FeatureSet, token:Object = null):void { if (featureSet.features.length == 0) { Alert.show("No mapable items found. Please try again."); } else { map.scale = zoomScale; map.centerAt(featureSet.features[0].geometry as MapPoint); var myGraphicMarker:Graphic = featureSet.features[0] as Graphic; myGraphicMarker.symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND, 22, 0x009933); var myGraphicsLayer:GraphicsLayer = new GraphicsLayer(); graphicsLayer.add(myGraphicMarker); //adding the graphics layer to the map map.addLayer(myGraphicsLayer); } }
var myGraphicMarker:Graphic = new Graphic(new MapPoint(featureSet.features[0].geometry), new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND, 22, 0x009933));
