Hi All
I have been looking for a solution to import Arabic characters with UTF-8 encoding in my shapefiles to my GDB as feature classes, but I lose most of the text.
Does anyone have a solution? looking everywhere
Jon
Hi Jonathan,
Take a look at the following stack exchange site. There are some step by step instructions that may help get you what you need:
convert - Character encoding support in geodatabases and shapefiles - Geographic Information Systems Stack Exchange
no tried it all regedit update to default UTF-8. the problem is that the shapefile has been created from a postgis database. Open Street Map (OSM) data and if I take into QGIS (the shapefile) I can then import it into and ESRI feature class and I have the text as normal.
I would like to update the shapefile, so that it reads the correct characters
thanks for the suggestion
Jonathan
Is this the article you are referring to
21106 - Read and write shapefile and dBASE files encoded in various code pages
and was a *.cpg file created in the database ? if so, was it incorrect? can you create a correctly encoded one in ArcMap? They can be created in a text editor if they are missing, but I haven't access to one with an alternate encoding than utf-8
Hi Dan,
Yes I have been using this article and haven't had any success, also created the .cpg file using a text editor and still no joy.
If I take it into a QGIS and save as shapefile with UTF-8 is works. I can send you a shapefile that I have issues with, and see if you have a solution. jonathan.mccloskey1@btinternet.com
Hi everyone!!
I have a little big problem , I have a file "File CPG (.cpg)",I try to open this in my ARCGIS10 but not let me "Invalid raster dataset. Failed to create raster layer". Any suggestions for open this file? My email is fhas33@gmail.com
Thank you
Hernandaz,
Posting this at the end of every post does not help get an answer to your question. You should post one (1) NEW question in the Imagery and Remote Sensing site and remove all your other posts.
Thanks.
Ok, thanks
2016-03-31 10:30 GMT-06:00 Rebecca Strauch, GISP <geonet@esri.com>:
GeoNet <https://community.esri.com/?et=watches.email.thread>importing UTF-8 shapefiles into feature classreply from Rebecca Strauch, GISP<https://community.esri.com/people/rastrauch?et=watches.email.thread> inDevelopers - View the full discussion<https://community.esri.com/message/598918?et=watches.email.thread#comment-598918>
