package com.esri.overlay { import com.esri.ags.Map; import com.esri.ags.geometry.Geometry; import com.esri.ags.geometry.MapPoint; import com.esri.ags.symbol.Symbol; import flash.display.Bitmap; import flash.display.Loader; import flash.display.LoaderInfo; import flash.display.Sprite; import flash.events.Event; import flash.events.IOErrorEvent; import flash.geom.Matrix; import flash.net.URLRequest; import flash.system.Capabilities; import flash.system.LoaderContext; import mx.controls.Label; public class OverlaySymbol extends Symbol { private const m_matrix:Matrix = new Matrix(); private var m_bitmap:Bitmap; private var m_source:Object; private var m_width:Number = 0; private var m_height:Number = 0; private var m_rotation:Number = 0; private var m_iname:String = ""; private var m_alpha:Number = 1; public function OverlaySymbol(source:String=null, width:Number=0, height:Number=0, rotation:Number=0, alpha:Number=1) { m_source = source; m_width = width; m_height = height; m_rotation = rotation; m_alpha = alpha; } [Bindable] public function get source():Object { return m_source; } public function set source(value:Object):void { if (value != m_source) { m_bitmap = null; m_source = value; dispatchEventChange(); } } [Bindable] public function get rotation():Number { return m_rotation; } public function set rotation(value:Number):void { if (value != m_rotation) { m_rotation = value; dispatchEventChange(); } } [Bindable] public function get width():Number { return m_width; } public function set width(value:Number):void { if (value != m_width) { m_width = value; dispatchEventChange(); } } [Bindable] public function get height():Number { return m_height; } public function set height(value:Number):void { if (value != m_height) { m_height = value; dispatchEventChange(); } } [Bindable] public function get alpha():Number { return m_alpha; } public function set alpha(value:Number):void { if (value != m_alpha) { m_alpha = value; dispatchEventChange(); } } override public function clear(sprite:Sprite):void { sprite.graphics.clear(); } override public function draw(sprite:Sprite, geometry:Geometry, attributes:Object, map:Map):void { if (geometry is MapPoint) { drawOverlay(sprite, MapPoint(geometry), map); } } private function drawOverlay(sprite:Sprite, mapPoint:MapPoint, map:Map):void { if (m_bitmap == null) { if (m_source is Class) { m_bitmap = new m_source(); drawBitmap(sprite, mapPoint, map); } else if (m_source is String) { var url : String = String(m_source); if( Capabilities.isDebugger == true ) { url = url + (url.indexOf("?") > -1 ? "&debug=true" : "?debug=true"); } const loaderContext:LoaderContext = new LoaderContext(); loaderContext.checkPolicyFile = true; const loader:Loader = new Loader(); loader.contentLoaderInfo.addEventListener(Event.COMPLETE, completeHandler); loader.contentLoaderInfo.addEventListener(IOErrorEvent.IO_ERROR, onLoaderError ); loader.load(new URLRequest(url), loaderContext); function completeHandler(event:Event):void { const loaderInfo:LoaderInfo = event.target as LoaderInfo; m_bitmap = loaderInfo.content as Bitmap; drawBitmap(sprite, mapPoint, map); } function onLoaderError(evt:Event):void { //do nothing } } } else { drawBitmap(sprite, mapPoint, map); } } private function drawBitmap(sprite:Sprite, mapPoint:MapPoint, map:Map):void { const width2:Number = m_width / 2.0; const height2:Number = m_height / 2.0; const xmin:Number = toScreenX(map, mapPoint.x); const xmax:Number = toScreenX(map, mapPoint.x + m_width); const ymax:Number = toScreenY(map, mapPoint.y); const ymin:Number = toScreenY(map, mapPoint.y + m_height); const width:Number = xmax - xmin; const height:Number = ymax - ymin; m_matrix.a = width / m_bitmap.bitmapData.width; m_matrix.d = height / m_bitmap.bitmapData.height; m_matrix.tx = width / m_bitmap.bitmapData.width; m_matrix.ty = height / m_bitmap.bitmapData.height; sprite.x = toScreenX(map, mapPoint.x); sprite.y = toScreenY(map, mapPoint.y); sprite.rotation = m_rotation; sprite.alpha = m_alpha; sprite.graphics.beginBitmapFill(m_bitmap.bitmapData, m_matrix, false, true); sprite.graphics.drawRect(m_matrix.tx, m_matrix.ty, width, height); sprite.graphics.endFill(); var tLabel:Label = new Label(); tLabel.text = m_iname; tLabel.x = sprite.x + 10; tLabel.y = sprite.y + 10; sprite.addChild(tLabel); } } }
sprite.addChild(yourUIComponent);
public override function draw(sprite:Sprite, geometry:Geometry, attributes:Object, map:Map):void { if (geometry is MapPoint) { var label:Label = new Label(); sprite.x = toScreenX(map, (geometry as MapPoint).x); sprite.y = toScreenY(map, (geometry as MapPoint).y); label.text = "dummy label"; label.x = sprite.x; label.y = sprite.y; label.alpha = 1; sprite.addChild(label); sprite.width = 50; sprite.height = 20; } else throw new Error("not a map point "); }
package org.calhoun.county { import com.esri.ags.Map; import com.esri.ags.geometry.Geometry; import com.esri.ags.geometry.MapPoint; import com.esri.ags.symbols.Symbol; import flash.display.Sprite; import flash.text.TextField; import flash.text.TextFieldAutoSize; public class MySymbol extends Symbol { public function MySymbol() { super(); } override public function clear(sprite:Sprite):void { sprite.graphics.clear(); } override public function draw(sprite:Sprite, geometry:Geometry, attributes:Object, map:Map):void { if (geometry is MapPoint) { var m_textField:TextField; sprite.x = toScreenX(map, (geometry as MapPoint).x); sprite.y = toScreenY(map, (geometry as MapPoint).y); m_textField = new TextField(); m_textField.name = "textField"; m_textField.mouseEnabled = false; m_textField.mouseWheelEnabled = false; m_textField.selectable = false; m_textField.autoSize = TextFieldAutoSize.CENTER; m_textField.text = "Dummy Text"; sprite.addChild(m_textField); sprite.width = 50; sprite.height = 20; } else throw new Error("not a map point "); } } }
I am not sure on the exacts of the requirements but it seems like spark primitives are necessary.
