Hi everyone,
I am new in python and have just started to write some simple scripts similar to the following one:
# Import arcpy module
import arcpy, os, sys
#Parameters
L= arcpy.GetParameterAsText(0)
O= arcpy.GetParameterAsText(1)
O_4= arcpy.GetParameterAsText(2)
#Variables
O_4= O
#Select by location
arcpy.SelectLayerByLocation_management(O, "WITHIN", L,"", "NEW_SELECTION", "")
#Select by Attribute
arcpy.SelectLayerByAttribute_management(O_4, "SWITCH_SELECTION", "")
#calculate field
arcpy.CalculateField_management(O, "Feild2", '"Warning"', "VB")
#calculate field
arcpy.CalculateField_management(O_4, "Field2", '"ERROR"', "VB")
When I attempt to join those scripts outputs (by using "Join" tool) in ModelBuilder; I get this error: <<Error:000229: Cannot pen \\psf\Home\Documents\Default.gdb\finaloutput ; Failed to execute (Merge)>>
I have also set my parameters as following:
Display Name Data Type Type Direction
L Feature Layer Required input
O Feature Layer Required input
O_4 Table Required output
Do you have any solution for that?
