Hi
I was wondering is there a way to add Raster Datasets to a viewer in the same way that feature layers can be added. So I have 30 jpegs to publish, I would rather that they are all published in 1 Map Service rather than have 30 Map Services but when adding them to the flex viewer I need to have them as separate layers that can be turned on and off, individually zoomed to and transparency adjusted individually as some of the rasters overlap. I know that this can be done with feature layers by changing the type from dynamic to feature and adding the published layer number at the end of the url in the config so I was wondering how I would go about doing the same for separate Raster layers?
