<StackPanel> <slData:DataGrid x:Name="IdentifyDetailsDataGrid" AutoGenerateColumns="False" HeadersVisibility="None" Background="White"> <slData:DataGrid.Columns> <slData:DataGridTextColumn Binding="{Binding Path=Key}" FontWeight="Bold"/> <slData:DataGridTextColumn Binding="{Binding Path=Value}"/> </slData:DataGrid.Columns> </slData:DataGrid> <slData:DataGrid x:Name="IdentifyDetailsDataGrid2" AutoGenerateColumns="False" HeadersVisibility="None" Background="White"> <slData:DataGrid.Columns> <slData:DataGridTextColumn Binding="{Binding Path=Key}" FontWeight="Bold"/> <slData:DataGridTextColumn Binding="{Binding Path=Value}"/> </slData:DataGrid.Columns> </slData:DataGrid> </StackPanel>
public void ShowFeatures(List<IdentifyResult> results) { _dataItems = new List<DataItem>(); if (results != null && results.Count > 0) { IdentifyComboBox.Items.Clear(); foreach (IdentifyResult result in results) { Graphic feature = result.Feature; string title = result.Value.ToString() + " (" + result.LayerName + ")"; _dataItems.Add(new DataItem() { Title = title, Data = feature.Attributes }); IdentifyComboBox.Items.Add(title); if(result.LayerId == 3) IdentifyDetailsDataGrid.ItemsSource = feature.Attributes; else IdentifyDetailsDataGrid2.ItemsSource = feature.Attributes; } IdentifyComboBox.SelectedIndex = 0; } }
public void ShowFeatures(List<IdentifyResult> results) { _dataItems = new List<DataItem>(); if (results != null && results.Count > 0) { foreach (IdentifyResult result in results) { Graphic feature = result.Feature; string title = result.Value.ToString() + " (" + result.LayerName + ")"; _dataItems.Add(new DataItem() { Title = title, Data = feature.Attributes }); var fieldsToDisplay = new List<string>() { "School Name", "Address", "Zip", "Phone", "Website", "School District" }; var attributesToDisplay = new Dictionary<string, object>(); foreach (var item in feature.Attributes) if (fieldsToDisplay.Contains(item.Key)) attributesToDisplay[item.Key] = item.Value; if (result.LayerId == 4) IdentifyDetailsDataGrid.ItemsSource = feature.Attributes; IdentifyDetailsDataGrid.ItemsSource = attributesToDisplay; if (result.LayerId == 9) IdentifyDetailsDataGrid2.ItemsSource = feature.Attributes; IdentifyDetailsDataGrid2.ItemsSource = attributesToDisplay; if (result.LayerId == 14) IdentifyDetailsDataGrid3.ItemsSource = feature.Attributes; IdentifyDetailsDataGrid3.ItemsSource = attributesToDisplay; }
var temp = new Dictionary<string, object>(); var fields = new List<string>() {"field1", "field2"}; //fields to display foreach(var item in feature.Attributes) { if(fields.Contains(item.Key)) temp[item.Key] = item.Value; } //more code goes here Data = temp
<!--IDENTIFY TASK INTERFACE--> <StackPanel Margin="10" HorizontalAlignment="Right"> <Grid> <Rectangle Fill="#CC5C90B2" Stroke="Gray" RadiusX="10" RadiusY="10" Margin="0,0,0,-25" /> <TextBlock Text="School Attendance Area:" Foreground="White" FontSize="10" Margin="14,9,6,6" /> <StackPanel x:Name="IdentifyResultsStackPanel" Margin="15,30,15,10" Visibility="Collapsed"> <TextBlock Text="Select a result from the list to display additional info" Foreground="White" FontSize="10" FontStyle="Italic" Margin="0,0,0,5" /> <ComboBox x:Name="IdentifyComboBox" SelectionChanged="IdentifyComboBox_SelectionChanged" /> <ScrollViewer MaxHeight="340" Margin="0,10,0,0"> <slData:DataGrid x:Name="IdentifyDetailsDataGrid" AutoGenerateColumns="False" HeadersVisibility="None" LoadingRow="IdentifyDetailsDataGrid_LoadingRow"> <slData:DataGrid.Columns> <slData:DataGridTextColumn Binding="{Binding Path=Key}" FontWeight="Bold"/> <slData:DataGridTextColumn Binding="{Binding Path=Value}"/> </slData:DataGrid.Columns> </slData:DataGrid> <slData:DataGrid x:Name="IdentifyDetailsDataGrid2" AutoGenerateColumns="False" HeadersVisibility="None" LoadingRow="IdentifyDetailsDataGrid_LoadingRow"> <slData:DataGrid.Columns> <slData:DataGridTextColumn Binding="{Binding Path=Key}" FontWeight="Bold"/> <slData:DataGridTextColumn Binding="{Binding Path=Value}"/> </slData:DataGrid.Columns> </slData:DataGrid> </ScrollViewer> <ListBox x:Name="MyListBox" Height="200" Width="200" /> </StackPanel> </Grid> </StackPanel> </Grid> </UserControl>
//Displaying Identify Results. // Populate ComboBox with the results when Identify is complete. private void IdentifyTask_ExecuteCompleted(object sender, IdentifyEventArgs args) { IdentifyComboBox.Items.Clear(); // Check for new results. if (args.IdentifyResults.Count > 0) { // Show ComboBox and attributes DataGrid. IdentifyResultsStackPanel.Visibility = Visibility.Visible; // Add results to ComboBox. foreach (IdentifyResult result in args.IdentifyResults) { string title = string.Format("{0} ({1})", result.Value.ToString(), result.LayerName); IdentifyComboBox.Items.Add(title); } // Workaround for ComboBox bug. IdentifyComboBox.UpdateLayout(); // Store the list of Identify results. _lastIdentifyResult = args.IdentifyResults; // Initialize ComboBox and fire SelectionChanged. IdentifyComboBox.SelectedIndex = 0; } else { // Hide ComboBox and attributes DataGrid and notify the user. IdentifyResultsStackPanel.Visibility = Visibility.Collapsed; MessageBox.Show("No features found"); } }
var fieldsToDisplay = new List<string>() { "School Name", "Address", "Zip", "Phone", "Website", "School District" }; var attributesToDisplay = new Dictionary<string, object>(); foreach (var item in selectedFeature.Attributes) if (fieldsToDisplay.Contains(item.Key)) attributesToDisplay[item.Key] = item.Value; IdentifyDetailsDataGrid.ItemsSource = attributesToDisplay;
if (args.IdentifyResults.Count > 0) { IdentifyResultsStackPanel.Visibility = Visibility.Visible; foreach (IdentifyResult result in args.IdentifyResults) { string title = string.Format("{0} ({1})", result.Value.ToString(), result.LayerName); IdentifyComboBox.Items.Add(title); }
if (e.IdentifyResults.Any(r => r.LayerId == 1)) { var resultsFrom1 = e.IdentifyResults.Where(r => r.LayerId == 1); displayComboBoxFrom1.ItemsSource = resultsFrom1; } if (e.IdentifyResults.Any(r => r.LayerId == 2)) { var resultsFrom2 = e.IdentifyResults.Where(r => r.LayerId == 2); displayComboBoxFrom2.ItemsSource = resultsFrom2; }
