I'm wondering if it is possible to perform a table join in Microsoft Excel with ESRI For Office (similar to what can be done in ArcMap)? I have an Excel-table with two columns: an ID-number and a short information-string. I would like to join this table with a layer published to ArcGIS Online from ArcServer. The layer published to ArcGIS Online contains polygons with ID-numbers corresponding to those in the Excel-file (stored as attribute-values).
So, I'm able to create a "base map" in Excel, and I'm able to read the ArcGIS Online-layer to that map. But I'm uncertain where to go from here. I have tried using the add "From Excel"-tool on the map and selecting either a series of cells or the entire table and then selecting the "place type" of my imported ArcGIS Online-layer (which should work if I'm reading the documentation/help correctly), but the data-import fails consistently on every row in the excel-table.
Am I missing something here, or is this type of workflow not possible?
