Regarding the first part of your question, when you create the script tool parameters, make sure that you select the Obtained From box for the SQL Expression, and select the input feature that you want the fields to come from.
You shouldn't need a feature layer. It works as shapefile or feature class for me. Are the fields you want coming from the shapefile parameter below the SQL expression parameter, or are you trying to obtain the fields from a feature class that is defined within the script (not a parameter).
#Set Workspace arcpy.env.workspace = arcpy.GetParameter(0) arcpy.AddMessage("The new current workspace is: %s" % env.workspace) #Overwrite features arcpy.env.overwriteOutput = True # Get cnddb data and boundary input/output input_poly = r"K:\Library\State\CA\State_Wide\Bio\CNDDB\cnddb.shp" Input_Poly_Feature_Layer = "cnddb_Feature_Lyr" Buffer_output = "Buffer_Output" Buffer_Distance = arcpy.GetParameter(1) Selected_cnddb_poly = "cnddb_poly_selected".format(arcpy.GetParameter(1)) Selected_cnddb_point = "cnddb_point_selected".format(arcpy.GetParameter(1)) Selectingpoly = arcpy.GetParameter(2) SQL_Query = arcpy.GetParameterAsText(3) UpdatedField = "Cnddb_update" # Make Feature layer from cnddb poly arcpy.AddMessage("Creating CNDDB Polygon Feature Layer...") arcpy.MakeFeatureLayer_management(input_poly, Input_Poly_Feature_Layer) #Select by location cnddb polygon arcpy.AddMessage("Selecting features by location...") arcpy.SelectLayerByLocation_management(Input_Poly_Feature_Layer, 'WITHIN_A_DISTANCE', Selectingpoly, Buffer_Distance, "NEW_SELECTION") int(arcpy.GetCount_management(Input_Poly_Feature_Layer).getOutput(0)) #Select Layer by attribute SelectLayerByAttribute_management(Input_Poly_Feature_Layer, "SUBSET_SELECTION", SQL_Query)
Well, you do need a Feature Layer to use the Select Layer by Location tool, so if you drag and drop a shapefile, this will likely give you an error. However, if you completely take your script out of the equation, you should be able to do the following:1. Right click your toolbox and select Add > Script2. Click Next through the first 2 pages3. On the parameter page, make your first parameter a feature class, and call it "input feature"4. Make a second parameter called "SQL Expression" and select data type of SQL Expression5. For the second parameter, in the properties, select obtained from "input feature"6. Finish the tool, then double click it in the toolbox7. Fill in the tool with a shp/fc8. Click the SQL button and you should see the fields from the first parameterSee if this works, and if it does, implement the same type of logic into your script.
# Import system modules import arcpy from arcpy import env # Set the workspace env.workspace = arcpy.GetParameterAsText(0) Dir = env.workspace # Local variables input = arcpy.GetParameterAsText(1) polygon = arcpy.GetParameterAsText(2) expression = arcpy.GetParameterAsText(3) name = arcpy.GetParameterAsText(4) # Make a layer from the input feature class arcpy.MakeFeatureLayer_management(input, "lyr") # Select all points or polygons which overlap the polygon/s of interest arcpy.SelectLayerByLocation_management("lyr", "intersect", polygon, 0, "new_selection") # Within selected features, further select based on a SQL query within the script tool arcpy.SelectLayerByAttribute_management("lyr", "SUBSET_SELECTION", expression) # Write the selected features to a new featureclass arcpy.CopyFeatures_management("lyr", Dir + "\\" + str(name))
I think I understand what you want. Basically, you want the SQL query to reflect a table that is not a parameter but rather, a selection from a table. Based on what you describe, I don't believe it would be possible. The reason being is that you would want the SQL Query to reflect the selection, however, the selection wouldn't really be made until the script has started. However, at the time of clicking the SQL button, the script wouldn't have any way of knowing what the selection would be, as it was not executed yet.
Yes, have that as an input parameter and use Obtained From for the SQL Query.
You could probably set an error message if the user changes it using a ToolValidator class.
