HiJust working on getting a nice legend for my service. I have followed the instructions and the legend works fine however i require checkboxes for each sublayer in the service instead of the higher layer. Does anyone know how i would be able to achieve this?I would like to do it automatically so i dont need to manually change anything when using the code in another application for example. I just would like it to loop through, see sublayers and add the option for a checkbox to turn it on/off, unsure why this is not included as it seems so common for end users to do???thanks
function getSubLayers(layer) { var infos = layer.layerInfos, info, i, il, subLayerArray; for (i=0, il = infos.length; i<il; i++) { info = infos; if (!info.subLayerIds) { // if the layer doesn't have a subLayer, ... subLayerArray.push(info.id); // ...function adds the layer's id to an array } } return subLayerArray; }
thanks for the reply, will have a crack at it next week.I see from the code that it will retrieve the sublayers....still a bit unsure how to get the check boxes in the first TOC and not in the second one, will do some investigation.thanks again.
