<?xml version="1.0" encoding="UTF-8"?> <ESRI.Configuration xmlns="http://schemas.esri.com/Desktop/AddIns" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <Name>TestAddIn3</Name> <AddInID>92421ca6-0137-1000-5000-93a2889e0000</AddInID> <Description></Description> <Version>1.0</Version> <Image></Image> <Author></Author> <Company></Company> <Date>Mon May 28 09:03:55 CEST 2012</Date> <Targets> <Target name="Desktop" version="10.0"/> </Targets> <AddIn language="JAVA" library="TestAddIn3.jar"> <ArcMap> <Commands> <Button caption="NewButton1" category="JavaCommands" class="Button1" id="button1"/> </Commands> </ArcMap> </AddIn> </ESRI.Configuration>
INFO::Using the following arguments to create the JVM -Djava.class.path=C:\Program Files (x86)\ArcGIS\Desktop10.0\\java\lib\arcobjects.jar -Xms64m -Xmx128m -Xss512k -Xdebug -Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=8013 INFO::Successfully created an instance of : com/esri/arcgis/addinframework/AddInFactory
import java.io.IOException; import com.esri.arcgis.addins.desktop.Button; import com.esri.arcgis.framework.IApplication; import com.esri.arcgis.interop.AutomationException; public class Button1 extends Button { /** * Called when the button is clicked. * * @exception java.io.IOException if there are interop problems. * @exception com.esri.arcgis.interop.AutomationException if the component throws an ArcObjects exception. */ @Override public void onClick() throws IOException, AutomationException { // TODO Auto-generated method stub } @Override public void init(IApplication app) throws IOException, AutomationException { // TODO Auto-generated method stub super.init(app); } }
INFO::Successfully created an instance of : com/esri/arcgis/addinframework/AddInFactory java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) Caused by: java.lang.UnsupportedClassVersionError: Button1 : Unsupported major.minor version 51.0 ...
