I created application using Zone Lookup template however I have issue with displaying pin with searched address on the map. According to the settings it should show the pin..
Hi Liana,
With the settings you have set, we should be seeing a pin in the map. Did you click on the map to get the result, or did you use the search option to find the address?
Are you seeing this behavior while the application is launched as well, or only while in the configuration mode?
Thanks!
Sarah
Hi Sarah,
thank you for your response. I see this behavior from both configuration and launch mode.
And I am not getting pin in both cases: when I enter address or click on the map.
Can you clear your browser cache? Would it also be possible to provide the link to the application?
-Sarah
