i took a look at the information you posted about the GP service above and perhaps you need to be passing an ObjectID as well? if you hit a wall, i highly recommend testing directly in REST until you can figure out exactly what JSON is expected/required to run the service. its a lot easier to reverse engineer in your Javascript application than it is to discover what REST is looking for.the link below is related to a geocoding task rather than geoprocessing task, but it gives an example of the json for a recordset which has no geometry.http://resources.arcgis.com/en/help/rest/apiref/geocodeaddresses.html
Ann, [INDENT]make sure to use version 3.1 of the JS API as the issue mentioned below was fixed at 3.1 and might cause some problems for your particular workflow:[/INDENT] NIM083266: esri.tasks.FeatureSet.toJson() should ignore the featureSet's fields property when it is an empty array. John
function findAddress(){ gp = new esri.tasks.Geoprocessor("http://psc-gis-1/AGServer/rest/services/Tools/GeocodeAddress/GPServer/Geocode Address"); gp.setOutSpatialReference({wkid:4326}); var attr={"STANDARD":dijit.byId("address"), "ZIPCODE":dijit.byId("zipcode")}; var graphic = new esri.Graphic(null,null,attr,null); var features=[]; features.push(graphic); var featureSet=new esri.tasks.FeatureSet(); featureSet.features=features; var params= {"Input_Table":featureSet} esri.show(progress); gp.submitJob(params, completeCallback , statusCallback,function(error){ alert(error); esri.hide(progress); }); }
as an alternative, since many tasks actually return a recordset, it might also make sense to seperate the geocoding from the rest of your geoprocessing and pass the result from the first rather than creating the recordset from scratch.
//populate your attributes using name value pairs var attr = {"Plant":"Mesa Mint", "Field2:"Value2"}; //graphics doesn't require geometry, symbology or an info window, so you can just pass in attributes var graphic = new esri.Graphic(null,null,attr,null); //create an empty array var features= []; //push in your attributes features.push(graphic); //create your featureSet and push in the feature var featureSet = new esri.tasks.FeatureSet(); featureSet.features = features;
