Hi~~~
Could you give me an example of the ".find()"?
You can experiment on your own... for example given a list of text values `find` locates the first index occurrence of a string. Remember iterables are indexed from 0, a value of -1 indicates it wasn't found
a <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'wet'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'souwet'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'western'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> i <SPAN class="keyword token">in</SPAN> a<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">.</SPAN>find<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'wet'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="number token">0</SPAN> <SPAN class="number token">3</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
thank you so much~~~
