Hi, We eventually went down to oracle 11.2.0.1 but we also made the following changes , so maybe this will help you:1.Take the shape.so lib from the arcsde installation for unix and not from arc catalog as describe in the documentation ( we have tested it twice to be sure , the file from windows arc catalog is not working ). 2.Make sure that the path is ok , using these syntax, �?�SELECT * FROM USER_LIBRARIES3.We've followed these steps provided by our local distributer , step by step : a.Modify your extproc.ora as follows: SET EXTPROC_DLLS=ONLY:�?�.�?�(path)�?�.�?� libst_shapelib.so b.Re-create the libraries: $sqlplus sde/sde SQL> create or replace library ST_SHAPELIB as '�?�.�?�(path)�?�.�?� libst_shapelib.so '; Library created. c.Make sure that the dlls are valid. SQL>select * from user_libraries; Make sure it is pointing to the correct path and is valid. d.Compile st_geometry_shapelib_pkg SQL> alter package sde.st_geometry_shapelib_pkg compile reuse settings; Package altered. e.Creating the library causes dependent object to become invalid. Execute the following command as the SDE user (you may need to grant the execute privilege on sys.utl_recomp to user SDE): i.As sys user, grant execute on SYS.UTL_RECOMP TO SDE. SQL> GRANT EXECUTE ON SYS.UTL_RECOMP TO SDE; ii.As SDE user, recompile. SQL> EXECUTE sys.utl_recomp.recomp_serial('SDE'); f. Verify all objects are valid as SDE user. SQL> select object_name, object_type from user_objects where status = 'INVALID' g.Remove for now the "tnsnames+listener" config and see if it workshope this will work for you iris hadar
in my situation, the library was corrupted (for some reason).....
SDE /var/opt/esrilibs 12 > ldd libst_shapelib.so libclntsh.so.10.1 => /u01/app/oracle/product/11.2.0/dbhome_1/lib/lib clntsh.so.10.1 libCrun.so.1 => /usr/lib/64/libCrun.so.1 libnnz11.so => /u01/app/oracle/product/11.2.0/dbhome_1/lib/libnnz11.so libkstat.so.1 => /lib/64/libkstat.so.1 libnsl.so.1 => /lib/64/libnsl.so.1 libsocket.so.1 => /lib/64/libsocket.so.1 libresolv.so.2 => /lib/64/libresolv.so.2 libgen.so.1 => /lib/64/libgen.so.1 libdl.so.1 => /lib/64/libdl.so.1 libsched.so.1 => /usr/lib/64/libsched.so.1 librt.so.1 => /lib/64/librt.so.1 libc.so.1 => /lib/64/libc.so.1 libaio.so.1 => /lib/64/libaio.so.1 libpool.so.1 => /usr/lib/64/libpool.so.1 libm.so.2 => /lib/64/libm.so.2 libmp.so.2 => /lib/64/libmp.so.2 libmd.so.1 => /lib/64/libmd.so.1 libscf.so.1 => /lib/64/libscf.so.1 libxml2.so.2 => /usr/lib/64/libxml2.so.2 libnvpair.so.1 => /lib/64/libnvpair.so.1 libexacct.so.1 => /usr/lib/64/libexacct.so.1 libdoor.so.1 => /lib/64/libdoor.so.1 libuutil.so.1 => /lib/64/libuutil.so.1 libpthread.so.1 => /lib/64/libpthread.so.1 libz.so.1 => /usr/lib/64/libz.so.1 /platform/SUNW,Sun-Fire-V240/lib/sparcv9/libc_psr.so.1 /platform/SUNW,Sun-Fire-V240/lib/sparcv9/libmd_psr.so.1
# TNSNAMES.ORA Network Configuration File: /app_root/network/admin/tnsnames.ora # Generated by Oracle configuration tools. EXTPROC_CONNECTION_DATA = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC)) ) (CONNECT_DATA = (SID = PLSExtProc) (PRESENTATION = RO) ) ) o11g = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = archeo)(PORT = 1521)) ) (CONNECT_DATA = (SID = o11g) ) )
# LISTENER.ORA Network Configuration File: /app_root/network/admin/listener.ora # Generated by Oracle configuration tools. LISTENER = (DESCRIPTION_LIST = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC)) ) (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = archeo)(PORT = 1521)) ) ) ) SID_LIST_LISTENER = (SID_LIST = (SID_DESC = (SID_NAME = PLSExtProc) (ORACLE_HOME = /u01/app/oracle/product/11.2.0/dbhome_1) (PROGRAM = extproc) (ENVS = "EXTPROC_DLLS=/var/opt/esrilibs/libst_shapelib.so,LD_LIBRARY_PATH=/var/opt/esrilibs") ) (SID_DESC = (GLOBAL_DBNAME = o11g.iaa.local) (ORACLE_HOME = /u01/app/oracle/product/11.2.0/dbhome_1) (SID_NAME = o11g) ) ) ) SUBSCRIBE_FOR_NODE_DOWN_EVENT_LISTENER=OFF INBOUND_CONNECT_TIMEOUT_LISTENER=500
SET EXTPROC_DLLS=ONLY:/var/opt/esrilibs/libst_shapelib.so SET LD_LIBRARY_PATH=/var/opt/esrilibs:/u01/app/oracle/product/11.2.0/dbhome_1/lib
LIBRARY_NAME FILE_SPEC DYNAMIC STATUS ------------------------------ --------------------------------------------------------------------- ST_SHAPELIB /var/opt/esrilibs/libst_shapelib.so Y VALID
select st_point(0,0,0) from dual
SQL*Plus: Release 11.2.0.3.0 Production on Fri Dec 15 05:55:23 2012 Copyright (c) 1982, 2011, Oracle. All rights reserved. Connected to: Oracle Database 11g Enterprise Edition Release 11.2.0.3.0 - 64bit Production With the Partitioning, OLAP, Data Mining and Real Application Testing options SQL> select st_point(0,0,0) from dual; select st_point(0,0,0) from dual * ERROR at line 1: ORA-06520: PL/SQL: Error loading external library ORA-06522: ld.so.1: extproc: fatal: libclntsh.so.10.1: open failed: No such file or directory ORA-06512: "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 12 ORA-06512: "SDE.ST_POINT", line 176
% sqlplus sde/redacted@o11gR2a SQL*Plus: Release 11.2.0.2.0 Production on Fri Dec 14 16:42:37 2012 Copyright (c) 1982, 2010, Oracle. All rights reserved. Connected to: Oracle Database 11g Enterprise Edition Release 11.2.0.2.0 - 64bit Production With the Partitioning, OLAP, Data Mining and Real Application Testing options SQL> select st_point(0,0,0) from dual; ST_POINT(0,0,0)(ENTITY, NUMPTS, MINX, MINY, MAXX, MAXY, MINZ, MAXZ, MINM, MAXM, -------------------------------------------------------------------------------- ST_POINT(1, 1, 0, 0, 0, 0, NULL, NULL, NULL, NULL, 0, 0, 0, '0C00000001000000808 0DD9DA4178080DD9DA417')
Please provide the listener.ora and tnsnames.ora files from your$ORACLE_HOME/network/admin directory.- V
