I am using Visual Studio 2019 with ASP.NET Core to develop a web application. I need to add a component where it shows a map. I thought of using the ArcGIS JavaScript API. However, I am not able to display the map when following the instructions of the first tutorial to display a simple map. Note that I am using the Views (.cshtml files) to diplay it. When creating a .html file, it works, the map is displayed correctly, but not for the .cshtml. Is there a specific way to setup this API when working with ASP.NET?
Also, I saw there is also an ArcGIS Pro SDK, which works with ASP.NET, will it also helps me achieve my goal??
The main functionality of my application must be to display a map, and inside that map, show different kmz/kml files.
Thanks in advance
