Also we are considering the following GP tools at 10.2.2:Data Management > Raster > Mosaic Dataset > Create Mosaic DatasetData Management > Raster > Mosaic Dataset > Add Rasters To Mosaic DatasetMark
You can author data and ... publish it for use in a runtime application. The new way of doing this is via a geodatabase file although the classes to read geodatabases are currently in Beta at 10.2. However there is a release coming out very soon where these classes will be final. If you wait a few weeks then I'd recommend using the geodatabase route. Geodatabases can also be exported from ArcGIS Server Feature Services which enable you to edit data offline and then sync when you are back in network coverage. The other advantage of geodatabase files is that they are supported by all runtime SDKs unlike the Local Server which is only on Java, Qt and WPF.
