Eric, The code is there to support them, I just forgot to update the xml.<enablecircleselect>true</enablecircleselect> <enableellipseselect>true</enableellipseselect>
All, An updated version is now available:* 3.3.2 - Fixed issue where user was presented with login dialog even though token was provided in main config.xml - Added circle and ellipse tools - Applied workaround for ArcGIS Server 10 services sometimes not returning identify results in requested map projection.
<url>https://www.segland.com/ArcGIS/rest/services/WILDHORSE_POLK_COUNTY/MapServer/10/?token=AZjKCColLtfGWdUPGHI6dCxCzMREpfPjW_VM108WJA2JeGe0kJjqeIzo9GQa6zIw0TrPn2h9TLinlqHwYiX98w..</url>
<url>https://www.segland.com/ArcGIS/rest/services/WILDHORSE_POLK_COUNTY/MapServer</url>
<excludelayer url="http://segland.com/ArcGIS/rest/services/WILDHORSE_POLK_COUNTY/MapServer/0" id="0"/> <excludelayer url="http://segland.com/ArcGIS/rest/services/WILDHORSE_POLK_COUNTY/MapServer/9" id="9"/> <!-- <excludelayer url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/MapServer" id="2"/> -->
<excludelayer url="http://segland.com/ArcGIS/rest/services/WILDHORSE_POLK_COUNTY/MapServer" id="0"/> <excludelayer url="http://segland.com/ArcGIS/rest/services/WILDHORSE_POLK_COUNTY/MapServer" id="9"/> <!-- <excludelayer url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/MapServer" id="2"/> -->
setMapAction(DrawTool.MAPPOINT, status, identMarkerSymbol, drawEnd, false, true);
- Mouse over graphics now works even if you have the widget set to keepidentifyactive.
<field name="ESRIdate" alias="Date"/>popuponly="true" dateformat="YYYY/MM/DD" useutc="true"/>
<field name="ESRIdate" alias="Date" popuponly="true" dateformat="YYYY/MM/DD" useutc="true"/>
<fields all="true" />
<fields all="true"> <!-- <field name="Address" alias="Address" /> <field name="City" alias="City" popuponly="true"/> <field name="State" alias="State" popuponly="true"/> <field name="Postcode" alias="Postcode"/> --> </fields>
Hi Robert,I am getting a 1085 error when using the Identify 3.01 tool. I followed your PDF help file in constructing the <layers> portion of the syntax, the rest of the syntax remains unchanged from the tool as I downloaded it. Yes, the REST service name is what is used for the <name> tag. Here is my syntax:<layers onlythese="true">
-locale en_US -source-path=assets/locale/{locale} -keep-all-type-selectors=true
-locale= -source-path=assets/locale/{locale} -keep-all-type-selectors=true
Serena, What do your additional compiler arguments look like for your project when you look at your projects properties > Flex Compiler?
