some words of caution1.1.1 uses CRS1.3.0 uses SRShave you triedwmsLayer.SpatialReference = new esri.SpatialReference({wkid:3857}); or whatever you want it to be?btw 3857 and 102100 are the same thing
Thx for your answer...I did try it before but I double check and it's not workingRegarding SRS I think is the other way around right? (SRS for 1.1.1 and CRS for 1.3.0) the call generated is something like this:https://services.digitalglobe.com/mapservice/wmsaccess?CONNECTID=xyz&SERVICE=WMS&REQUEST=GetMap&FORMAT=image/png&TRANSPARENT=TRUE&STYLES=&VERSION=1.1.1&LAYERS=DigitalGlobe:Imagery&WIDTH=1053&HEIGHT=651&SRS=EPSG:102100&BBOX=-9382860.162660452,4998573.770502064,-9377829.6507363,5001683.8020905(changing to 1.3.0 call is the same but CRS)https://services.digitalglobe.com/mapservice/wmsaccess?CONNECTID=xyz&SERVICE=WMS&REQUEST=GetMap&FORMAT=image/png&TRANSPARENT=TRUE&STYLES=&VERSION=1.3.0&LAYERS=DigitalGlobe:Imagery&WIDTH=1053&HEIGHT=651&CRS=EPSG:102100&BBOX=-9382860.162660452,4998573.770502064,-9377829.6507363,5001683.8020905and I got back a 403 (FORBIDDEN) .. if I replace both 102100 with 3857 I got back the image...
I use expressserver from lizardtech, maybe its different.I know support for 102100 did not exist out of the box, i needed to manually configure the server to handle it. Maybe digitalglobe needs to do the same?
<CODE><SPAN class="" style="color: #303336; border: 0px; font-size: 13px;"><SPAN style="font-family: arial, helvetica, sans-serif;">Same issue still in version 3.20, but from this <A href="http://gis.stackexchange.com/questions/141040/arcgis-javascript-api-how-to-define-spatial-reference-for-wms-layer" rel="nofollow noopener noreferrer" target="_blank">StackOverflow post</A> it can be changed before adding the WMS layer to the map.</SPAN><BR /></SPAN>
wmsLayer<SPAN class="punctuation token">.</SPAN>spatialReferences<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="number token">3857</SPAN><SPAN class="punctuation token">;</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayers</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>wmsLayer<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
<SPAN class="" style="color: #303336; border: 0px; font-size: 13px;"> </SPAN>
