<layer label="BRT" type="wmts" visible="true" icon="assets/images/basemap_topographic.jpg" servicemode="KVP" layerid="brtachtergrondkaart" imageformat="png8" url="http://geodata.nationaalgeoregister.nl/tiles/service/wmts?VERSION=1.0.0&REQUEST=GetTile&TileMatrixSet=EPSG:28992" />
[h=3]Attributes specific to WMTSUnlike the WMS type, there is no skipgetcababilities attribute. Since this is the case, if the WMTS service does not have a crosdomain file associated with it, you will need to provide a proxy page URL. An example is provided below.servicemode???Optional, this specifies the WMTS service mode as either "KVP" or "RESTful"layerid???Optional, this is the layer you specifically want displayedSnippet showing how to add WMTS layer, make sure that the proxy is referenced in the <httpproxy> tag<map wraparound180="true" top="40"> <basemaps> <layer label="WMTSLayer" type="wmts" visible="true" useproxy="true" imageformat="gif" url="http://v2.suite.opengeo.org/geoserver/gwc/service/wmts" servicemode="KVP" layerid="world"/> </basemaps> </map>
Someone managed to use the service WMTS? I've tried with and without proxy unsuccessfully using the following settings in config.xml.<layer label="WMTSLayer" type="wmts" visible="true" useproxy="true" imageformat="PNG" url="http://v2.suite.opengeo.org/geoserver/gwc/service/wmts" servicemode="KVP" layerid="world"/>
