<layer> <token/> <definitionexpression></definitionexpression> <enableexport>true</enableexport> <name>Parcels</name> <url>http://server-name:6080/arcgis/rest/services/General_Mapservices/parcels/MapServer/2</url> <expressions> <expression alias="Parcel ID" textsearchlabel="Search by Parcel ID:"> <values> <value prompt="Example: 2724069035">coivector.COI.Parcels.ParcelPIN = upper('[value]')</value> </values> </expression> <expression alias="Owner Name" textsearchlabel="Search by owner name:"> <values> <value prompt="">Assessor_Info.GISMAP.%ParcelInfo.PropertyOwner LIKE upper('%[value]%')</value> </values> </expression> <expression alias="Plat Name" textsearchlabel="Search by Plat Name:"> <values> <value prompt="Example: ENGLEWOOD ADD">coivector.COI.Parcels.PlatName LIKE upper('%[value]%')</value> </values> </expression> <expression alias="Site Name" textsearchlabel="Search by site name:"> <values> <value prompt="Example: GILMAN VILLAGE">Assessor_Info.GISMAP.%ParcelInfo.PropertyName LIKE upper('%[value]%')</value> </values> </expression> <expression alias="Appraised Land Value" textsearchlabel="Search using appraised land value:"> <values> <value prompt="include operator i.e. > 500000">Assessor_Info.GISMAP.%ParcelInfo.AppLandVal [value]</value> </values> </expression> <expression alias="Appraised Improvements Value" textsearchlabel="Search using appraised improvements value:"> <values> <value prompt="include operator i.e. > 1000000">Assessor_Info.GISMAP.%ParcelInfo.AppImprVal [value]</value> </values> </expression> <expression alias="Total Appraised Value" textsearchlabel="Search using total appraised value:"> <values> <value prompt="include operator i.e. > 2000000">Assessor_Info.GISMAP.%ParcelInfo.TotalAppVal [value]</value> </values> </expression> <expression alias="Appraised Land Value-sq. ft." textsearchlabel="Search using appraised land value per sq. ft.:"> <values> <value prompt="include operator i.e. > 90">Assessor_Info.GISMAP.%ParcelInfo.AppLandValSF [value]</value> </values> </expression> <expression alias="Appraised Improvements Value-sq. ft." textsearchlabel="Search using appraised improvements value per sq. ft.:"> <values> <value prompt="include operator i.e. > 200">Assessor_Info.GISMAP.%ParcelInfo.AppImprValSF [value]</value> </values> </expression> <expression alias="Total Appraised Value-sq. ft." textsearchlabel="Search using total appraised value per sq. ft.:"> <values> <value prompt="include operator i.e. > 200">Assessor_Info.GISMAP.%ParcelInfo.TotalAppValSF [value]</value> </values> </expression> <expression alias="Commercial Building Gross Total Sq. Ft." textsearchlabel="Search using commercial building total gross sq. ft.:"> <values> <value prompt="include operator i.e. > 500000">Assessor_Info.GISMAP.%CommBldg_GrossSF_by_PIN.CommBldgTotalGrossSF [value]</value> </values> </expression> </expressions> <graphicalsearchlabel>Use one of the graphical search tools to select parcels</graphicalsearchlabel> <spatialsearchlayer>true</spatialsearchlayer> <titlefield>ParcelPIN</titlefield> <fields all="false"> <field name="coivector.COI.Parcels.ParcelPIN" alias="Parcel PIN" gridfield="true"/> <field name="coivector.COI.Parcels.PlatName" alias="Plat Name" gridfield="true"/> <field name="Assessor_Info.GISMAP.%ParcelInfo.PropertyName" alias="Property Name" gridfield="true"/> <field name="Assessor_Info.GISMAP.%ParcelInfo.PropertyOwner" alias="Property Owner" gridfield="true"/> <field name="Assessor_Info.GISMAP.%ParcelInfo.OwnerAttention" alias="Owner Attention" gridfield="true"/> <field name="Assessor_Info.GISMAP.%ParcelInfo.OwnerAddress" alias="Owner Address" gridfield="true"/> <field name="Assessor_Info.GISMAP.%ParcelInfo.OwnerCityState" alias="Owner City-State" gridfield="true"/> <field name="Assessor_Info.GISMAP.%ParcelInfo.OwnerZipCode" alias="Owner ZipCode" gridfield="true"/> <field name="Assessor_Info.GISMAP.%ParcelInfo.Plat" alias="Plat" gridfield="true"/> <field name="Assessor_Info.GISMAP.%ParcelInfo.Lot" alias="Lot" gridfield="true"/> <field name="Assessor_Info.GISMAP.%ParcelInfo.Block" alias="Block" gridfield="true"/> <field name="Assessor_Info.GISMAP.%ParcelInfo.YearBuilt" alias="Year Built" gridfield="true" gridfieldonly="true"/> <field name="Assessor_Info.GISMAP.%ParcelInfo.LotSF" alias="Lot Sq Ft" gridfield="true"/> <field name="Assessor_Info.GISMAP.%ParcelInfo.AppLandVal" alias="Appraised Land Value" gridfield="true"/> <field name="Assessor_Info.GISMAP.%ParcelInfo.AppImprVal" alias="Appraised Improvements Value" gridfield="true"/> <field name="Assessor_Info.GISMAP.%ParcelInfo.TotalAppVal" alias="Total Appraised Value" gridfield="true"/> <field name="Assessor_Info.GISMAP.%ParcelInfo.TotalAppValSF" alias="Total Appraised Value Sq Ft" gridfield="true"/> <field name="Assessor_Info.GISMAP.%ParcelInfo.AppLandValSF" alias="Appraised Land Value Sq Ft" gridfield="true"/> <field name="Assessor_Info.GISMAP.%ParcelInfo.AppImprValSF" alias="Appraised Improvements Value Sq Ft" gridfield="true"/> <field name="Assessor_Info.GISMAP.%CommBldg_GrossSF_by_PIN.CommBldgTotalGrossSF" alias="Commercial Building Total Gross Sq Ft" gridfield="true"/> </fields> <icon isfield="false"></icon> <links/> <zoomscale usegeometry="true" zoompercent="2"></zoomscale> <autoopendatagrid>false</autoopendatagrid> </layer>
Just as an update - We are using ArcGIS for Server 10.3 and I have this issue with a linked server table. Thank you Brian Oevermann for posting your updates.
It should also note that the error was only occurring if I was trying to add all the layers from my rest end point as a group, rather then adding each layer individually.
I met this problem. Follow your suggestion it helps me.
