Any ideas on resolving the error message below? I am currently using ArcMap 10.3.1 and am able to import other project files in the same folder.
Good question. There are, and within the same folder (zoning01.apr). However I still get the same error.
using windows explorer, by chance are there *.apr files there that don't have the 'copy of...' attached to the name? I suspect that those files originated from a bad copy paste or a drag and drop into a folder that contained the originals. If you have the originals and they work, then I would just ignore/move the 'copy of...' versions to another location and proceed with the good ones.
Let me know if this helps. I use the "Import from ArcView Project" command which prompts me for the *.apr file. After selecting the file, I receive the error message. There are 6 different *.apr files in the "zoningMap" folder. Each one produces the same message. This might be notable: if I go "up" one folder to Y:\Projects\Westmoreland, all of the *.apr files import normally.
any more details?
