I'm creating a custom pop-up where I send the attribute table value into a function to reformat it. It's called like so:
<SPAN class="keyword token">var</SPAN> herbicide <SPAN class="operator token">=</SPAN> <SPAN class="string token">'${Herbicide1:herbName}'</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>It then enters the function like this (it has many more cases than what's shown):
herbName <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>value<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
herb <SPAN class="operator token">=</SPAN> <SPAN class="string token">''</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">switch</SPAN><SPAN class="punctuation token">(</SPAN>value<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">:</SPAN>
herb <SPAN class="operator token">=</SPAN> <SPAN class="string token">'None'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">break</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">:</SPAN>
herb <SPAN class="operator token">=</SPAN> <SPAN class="string token">'2,4-D'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> herb<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>The 'return herb' line should return the new value and I thought that the 'herbicide' variable would be set equal to whatever was returned, but that does not appear to be the case if I actually try to print it's value. When I print it:
>>> console.log(herbicide);
This is making it really hard to do conditional statements on the variable. For instance, if herbicide is set to 'None' then I don't want it to show up in the popup, but using this statement:
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>herbicide <SPAN class="operator token">==</SPAN> <SPAN class="string token">'None'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//do something</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>It will never evaluate true because unfortunately, no matter what value was returned from the function, the value being tested against is always the string '${Herbicide1:herbName}'
What's weird to me is that you can't see the value by printing it to the console, yet I know my functions are returning the correct values because it prints them correctly to a popup. I can't test the value I need to test... what can I do to fix that?
